mk3 polo gearbox in 1300 mk1 golf
(In Topic #105698)
![skelly in the usergroup ‘Regular’ skelly in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Phoenix in the usergroup ‘Local’ Phoenix in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
i did the swap on my Mk2 polo and although it would have been awesome on track for road use you get a bit sick of swapping gears
![yeha in the usergroup ‘Old timer’ yeha in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
yeha said
You don't need anything new in the linkage department but use the Polo ball and cage at the gearbox end. As said above, the GT box is great for B road thrashing, but a bit short geared for cruising. Go for the common 8P if you want to go places with a decent mpg figure. You will need a new gearbox mount fabricating though.
what age polos will i find the 8p box?
and what sort of a job is it fadricating the new gear box mount
THANKS!
as for the box try either
www.polo3.co.uk
or
www.clubpolo.com
Here's my mount:
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.tdeuk.com%2Fgolf%2Fmount.jpg)
yeha said
The mk3 Polo 1.3 is the easiest to find.
Here's my mount:
did your standard drive shafts fit this box or do you have to use the polo ones?
![ashleymk1 in the usergroup ‘Regular’ ashleymk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Remove the plastic strips from you gear selector under the gaitor gives greater movment to find 5th easier.
I had to swap over the output drives on the gearboxes so they matched (not sure if this because mines a series 1).
fit a new gbox gear selector seal from gsf. cost 2 quid and alot easier to fit whilst off and they always leak.
made my mount of half polo half golf very easy and looks factory. Although looking at yeha hes used big block end so rubber easier to obtain?
![Avatar]([URL=http://i35.photobucket.com/albums/d189/vr6lad/sig1.jpg][IMG]http://i35.photobucket.com/albums/d189/vr6lad/th_sig1.jpg[/IMG][/URL])
![scotboy in the usergroup ‘Local’ scotboy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
<a href="VW Golf Mk1 Owners Club"> <img
http://i35.photobucket.com/albums/d189/vr6lad/forumsig_h.jpg
![Avatar](https://i170.photobucket.com/albums/u273/foxymk1/4c562e71-99b8-4381-9a3b-a4fd488a04b4_zps153d729c.jpg)
![foxymk1 in the usergroup ‘Paid Member’ foxymk1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![foxymk1 in the usergroup ‘Local hero’ foxymk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
thnx foxy
![Holly83 in the usergroup ‘Local’ Holly83 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
jimmy
Ratty 83' 1100 Golf Now With 5 Speedsssssssss
(Holly)
93' Polo Coupe ! .. Mates Project Car (Poppy)
70' Beach Buggy - Holier Than A Church !!! (Lilly)
72' Beetle in a thousand pieces (bro's) (Daisy)
