Engine not running right
(In Topic #83733)
![Avatar](https://i14.photobucket.com/albums/a334/Pedrosgolf/MK1CitiSteeliesavatar.jpg)
![Peddersgolf in the usergroup ‘Local hero’ Peddersgolf in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Hi,
Was out 3am this morning on way to someones house, on motorway car was fine for approx 10 mile, just as i am coming off, car was losing power and juddering, i had to pull out the manual choke in order to keep the revs going, as i was continueing it was spitting and juddering all the way to my friends house, soon as i arrive nearby the car runs sweet and revs kickin so i turn choke off.
For past 3 week the car revs go high and low during the choke process when i run her for about 10 minutes from cold then all of a sudden the revs go really high and car runs sweet again, then i shut off choke.
On way bk home from my friend this morning car pulled and run smooth as a babies bottom as usual.
So today i decided how i would find out what the problem was, then i looked at the exhaust, it was very sooty.
So to see if this was anything to do with it, i cleaned the exhaust tip back to a nice chrome finish and went to big w approx 2 mile run.
when i got back home i noticed slight black splashes appearing on the tip again.
I am thinking of removing the carb and cleaning it to see if this is the problem and some crap has got into the carb from tank.
Would i be correct in doing this and thinking this would correct the problem or should i be looking else where.
I am planning on starting on her 1st thing in morning so any help would be really grateful.
Thank you
Thank you
![yeha in the usergroup ‘Old timer’ yeha in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Air leak under the carb? I had similar symptoms although I have the Polo SPI unit, but it fits like a carb. I lifted it off, cleaned up the mounting face and added a bit of sealant. Haven't had a problem since.
Thanks fella, will give that ago, was thinking something dow t carb, air leak etc, but best asking the experts :wink:
Best wishes and merry christmas bud
Expert? Where? There don't seem to be many small block experts, they all seem to drive the big block stuff, leaving the rest of us to struggle along blindly. Isn't yours a big block derivative?
![tupac2makaveli71 in the usergroup ‘Local’ tupac2makaveli71 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mate i have the same problem, its three things in my case, vaccum pipes not properly connected, wrong carb (1.3 webber i have a 1.1) and i think its running a little rich as thats what causes the exhaust to go black... its annoying when you first start your car its fine, then suddenly on idle it cuts out and you have to put the choke real out sometimes even hit the accelorater now and again right?
i live to dub....
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/snorkler.jpg)
![Tian in the usergroup ‘Local hero’ Tian in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
And a Merry Christmas to you too yeha!
Spreading the joy?
Tian
![phil-p in the usergroup ‘Regular’ phil-p in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Hi there mine does this. And has done this before. The carb is blocked up with crap, or the co is set wrong, this just needs a full carb strip and clean and the fuel filter replacing. and the carb base had split, this is just a rubber base that bolts through ur manifold that the carb sits on. They have a tendancy of splitin which lets more air in. think this is around ?30 from gsf. hope all goes well
Phil
Phil
Golf c mk1 1100, Needs more power
Yeha,
confusing isn't it, 1.3 but big block, thats how they are done in SA.
Well today i removed carb and flange cleaned them down and refitted, no petrol fumes either.
Phil flange was replaced when i bought her bk in april, no bubbles or splits.
Not had chance to set co's as yet as xmas day and its the boys day so didnt want to spoil it for them by working on the car too long.
I will carry on in the morning and take her for a drive, see how she is.
Tupac, mine is fitted with a keihin carb and yes excactly as you have described, even thou its a manual choke the problem is worst during the colder days, they should operate better in colder days than solex and pierburgs, i have a weber on my C 1.6 mk2 and it runs perfect even when really cold, no cut outs or anything.
Also Phil where abouts in salford are you, i know roughly the majority of mk1's floating about the area, a black Y 1.5 which is my friends, my other friend as a Y in a pearlesence colour with porsche alloys, a polish red cabbie, and a black cabbie gti which a women owns, but lately i have noticed a black mk1 on the scene, not you is it?
Ayway will let you know how i get on after tomorrow.
Again merry xmas and best wishes the new year
na thats not mine, (whish it was, that means i would still be driving mine) Mine is a light blue 3dr 1.1 on a a plate, it has been of the road for about 6 month now. And i am around the kersal prestwich area.
Good luck with ur car hope u get it sorted
Phil
Phil
Tried and tested with a 10 minute drive, after couople of minutes she run sweet, wash and waxed, polished and hoovered etc after that, so hopefully all ok.
Phil i am higher broughton, i am sometimes hunting round prestwich but if yours is off road, no wonder i have not seen it about.
best wishes bud
best wishes bud
![Avatar](https://i78.photobucket.com/albums/j95/citigolf_2006/Avatar0.gif)
![Bert in the usergroup ‘Local hero’ Bert in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Bert in the usergroup ‘Paid Member’ Bert in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
Peddersgolf i may know the problem
Mine is a 1.3 big block,notice the air filter housing has one inlet?? there is no hot air feed for our cold winters here so no hot air means carburettor freezing :roll: My GX did this when i took it down the motorway with the hot air pipe missing :wink:
The africans didnt expect the citi to be in -5 uk weather
Bert
Oh,if you mess carburettor is a keihin 26-30 DC. idle speed is 950 rpm,co content 1.5%,timing is 5-7 degrees BTDC with vac disconncted.
![](https://vwgolfmk1.org.uk/uploads/pbextract/694007/LeeWilliams1.jpg)
Bert
Bert,
Your a star fella,
Snap
Where i have put arrow, you mean dont you? if so is there any way of modifing that you know of that could cure this without having to replace the carb etc.
I know yours is locked up and looking gleaming, but mine is used everyday until i get another mk1 to play with.
I was thinking if no hot air is getting to carb, would blowing hot air from an air dryer into filter before starting on cold mornings sort it, just a thought :dontknow:
Co settings etc i have from my haynes so those are sorted.
Cheers bud
Pete :wink:
Your a star fella,
![](https://i14.photobucket.com/albums/a334/Pedrosgolf/My%20Mk%201/Enginebay.jpg)
Snap
Cheers bud
Pete :wink:
Carry on, don't mind me, just looking at the engine bay pic.
Tian :notworthy:
Tian :notworthy:
Thats it bert,the easiest way to sort the problem out is to use the complete assembly off a GX,or a similar carb set up,with hot air suction,it needs warm air in this weather when its at speed,round town it will be fine,the system uses a vacuum if i remember right,when the air temp sensor is cold enough the vacuum goes through the valve and sucks the flap to the 'hot air position' or keep away from fast roads in winter :?
Bert
Bert
Oh Crap, i am on way to lincoln this saturday
do you have a pic of a gx setup and where the vacuum pipes would connect to the air filter and carb on mine bud, plus most importantly anyone here have a gx setup for me please before saturday, otherwise it looks like rac will be coming out to me
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
![:|](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/mellow.png)
Bert you beat to it, i just remmembered something before you replied.
Well here goes, go on have a little chuckle to yourself :wink:
Am i stupid or what, bert when i bought the little beaut, there was black extension piping connect to the filter housing and it ran around to the back near exhaust and i though what a tit, why the hell would you want to do that, now i know it was for warm air
, well it'll teach me to mess with things hey.
Thats why if you look at my pic of cone part of housing, you'll see a screw where it was connected too
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Golf%20Ava5.jpg)
![markwon in the usergroup ‘Local hero’ markwon in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Strange, why did VW use a big block for the SA 1.3, while in Europe they used the small block to replace the big block 1.6 :dontknow:
1983 1100 C
1983 1100 C
