4speed linkage
(In Topic #73458)
4speed linkage
matt
Having said that - all I do is loosen everything off, get someone to sit in the car with the gearstick held about where it wants to be, tighen it all up and see how it feels.
I think Euro Car Parts od the annoying little "plastic ball" bit on the gearlinkage as this is the bit that usually breaks up - on my first Golf it got soo loose it dropped off and I had to drive 15 miles in 3rd gear!
It isn't this setup…
If this is a small block 4 speed, it is a straight rod change box - All the jiggery pokery is done inside the box, not like the Gti linkage setup.
I think the slop is probably the plastic ball at the bottom of your shifter though.
GSF website lists this which will probably contain whatever it is that is worn:
Pt No Description
71708 GEARLEVER REPAIR KIT G1 1.1 9/75 >12/83 ?4.95
71708 GEARLEVER REPAIR KIT G1 1.3 8/79 >12/83 ?4.95
Hope that helps…
My Build Thread
71707 GEAR LINKAGE SHIFT FINGER G1 1.1/1.3 4 Speed 81> ?15.00
My Build Thread
There is a little "hook and ball" type thing on the end of the shift rod but there were about four versions across the lift of the Mk1. All mine have been small block ones…
Another step closer
