1.3 driver not starting - no fuel
(In Topic #87801)
ive had a read through and seen various posts which are similar to my problems but nothing that seems to help me out.
so hopefully someone can point me in the right direction…
My car wont start, it will turn over but not fire up.
ive had a look under the bonnet and the fuel filter is completely dry.
i changed the fuel pump to a new unit, and checked the fuel line from the tank to the filter, so thats all clear.
ive been told there may be a airblock in the line? and if i drop a bit of fuel down the carb it will get things running and clear the block.
if anyone can confirm or sugest anything else that would b brilliant.
adz
owns:
mk1 jetta 1983 blue
1966 beetle on hydros
1959 lowlight karmann ghia
mk1 jetta 1983 blue
check your sender unit isnt blocked, (under rear bench) i found the best thing to do is to pour a little petrol down the carb as you said, it should fire up the engine and get the fuel flowing properly. if it runs for a few seconds then cuts out sounds like there is a block
or if it still doesnt run atall electrical problems maybe?
Greg 8)
1981 Golf C 1.1
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
1982 Golf GTI
1992 Corrado G60
1999 Golf GT TDI
if its not that i hav no idea! lol
i will put a new one on tomorrow and let u know
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
its only done 48,000 so its in pretty good condition under the bonnet, and has been serviced at VW since new. must just be the coil has given in?
what do u think?
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
