Wheel spacer
(In Topic #75191)
![lhasa in the usergroup ‘Old timer’ lhasa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Wheel spacer
![m6m62 in the usergroup ‘Old timer’ m6m62 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Depends on wheels / bolts used really (ie, how much thread goes into drum). I'm using 3mm spacers on the front of my Caddy (BBS RD alloys and std. bolts) and have no problems. Had to use them as the wheels are ET40 and just skimmed the strut on the n/s (!). 3mm hardly anything though ………..
Cheers,
Mark
![andunp in the usergroup ‘Local’ andunp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
i run a vw t25 camper and that has 25mm on each side (50mm per axle)
and its sweeeeet
theres a guy called fireturk i think he goes on ebay but he makes up spacers and extended bolts pretty cheap too 8)
![moreno in the usergroup ‘Local’ moreno in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![tallpete in the usergroup ‘Old timer’ tallpete in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Otherwise your wheels are hanging off the bolts only, not good.
Peter.
1980 1600 GTI, daily driver.
