What size wheels do I choose?
(In Topic #132008)
What offest should I go for/size should I go for? Got coilovers on the car at the moment and rolling the arches shouldn't be a problem if required.
Anyone got advice or maybe done this already? I don't want any rubbing issues if poss!
Thanks…
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
No. standard brakes.
16" rims will require tyres so low profile, they'll give almost no flex so it will accentuate the harshness of the hard suspension with coilovers, and alter the handling balance so much that the car will grip to a point (better than standard, if you pay attention to the correct geometry settings) but then when they do 'let go', will probably result in a lot of oversteer rather than progressively worse understeer with increasing cornering speed.
As soon as you go wider than standard and drop it, you are going to get either:
1 - Tyre contact with the coilovers
2 - Tyre contact with the arches
…depending on offset.
Any reason you want 16's? 15's normally look plenty big enough… :dontknow:
My Build Thread
I had 15's on a mk1 driver I had about 10 years ago and fancied going a bit bigger.
The car will be used at weekend so I won't be carrying people/suit cases etc which should help regarding the rear arches.
Sorry yes the following post is correct 7inch wide et 35 will probably hit the stupid coilovers if wound down behind the tyre.
abfmk1 said
Pretty sure and you can probably check on one of those tyre websites that a 195/45 x 16 tyre is a very similiar height to a 195/50 x 15 tyre, so as long as you go no wider than a 7 inch rim, stick to about et35 and dont lower too much things should be hunky dory.
ET38 and a 6 inch rim (Standard) can give probs with tyre contact against spring/spring seat when using coilovers.
et35 is only giving you 3mm in the right direction on the offset, though the fact that the wheel is now 7" wide (0.5 inches either side of the centreline, this pushes you approx 12.5mm back the other way meaning overall, you are nearly 10mm closer to the spring!
Add to this the camber setting…
Wheels really are a problem when you start to go for non standard sizes. You should go with a tried and tested set-up, or if possible, try before you buy, otherwise, there is an element of risk! :dontknow:
My Build Thread
16 rims....
have got 16 borbet a on mk1……rears are 9x16 with et 15….tyres are 215 35 16,,,,on adjustables and at right height no rubbing……. fronts are best with 7 1/2 16 et 20…..with same tyres all ok……
Any recommendation to an alloy wheel supplier who'd be able to advise and is reasonably priced?
I appreciate all your comments…really helpful.
wheels
Any views?
WELL DONE
I have spent a fair amount of time getting my car running right with aftermarket wheels. I am running the car very low on static coils, so I haven't made life easy for myself. the wheels are Zender 15" x 7"
This has been an expensive nightmare to get this lot rolling without fouling, however there is still a bit on cornering.
The wheels are mounted on hubcentric spacers, 18mm front and 25mm rear. the fronts were needed as the wheels were locked solid against the coils when I first fitted them, the rear is for looks.
The rear arches are "butchered" and bear little resemblance to the standard car. Lips are totally removed, plastic arches ground back to match.
also running 1 degree neg camber on the rear.
It took several weeks to get the wheels on (not counting the 2 months it took to cut out the rotten inner wheel arch and replace it)
There is always a price to pay for running non standard wheels, I ran 17's on 309 GTI back in 1997, that was hard work, but worth it, the car was featured in Revs magazine, had to work everything out for myself back then, no forums to help!
Hope you get something sorted soon!
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
chris-h said
Sorry to disagree with the local tyre firm but you aint getting 16" wheels an a cabrio with no clearance issues.
I agree.
Normally, the spring sits on the spring plate, which is up in the arch, above the top of the tyre.
With coilovers, the spring goes down behind the inner sidewall of the tyre. This is thicker than the old strut on its own and this is why you get issues.
mustang351 said
THE LOWER THE PROFILE THE BETTER THE HANDLING…LESS TYRE DISTORSION
I also disagree somewhat with this.
While a tyre wall is allowed to flex it "gives" when cornering, giving you a more predictable, forgiving cornering experience.
A small sidewall is unable to do this and when the tyre loses grip, it can do so very quickly, catching the driver out!
My Build Thread
AL_Mk1 said
I agree.
This is correct I can tell you from experience that 7x15 et38 (195 50 15 tyres) do not fit with coilovers. The tyre is squashed against the spring couldn't tell if the rim itself fouled but it would have been very very close the tyres on this combo sat proud of the rim. 7x15 et24 (175 50 15 tyres) fitted fine I could get my finger between the spring and the rim (this combo the rim was proud of the tyre).
Didn't ride or handle that well on the second combo but didn't ever have any rubbing despite running it pretty low.
I guess this is part of the reason "bags" are fitted to every car in PVW at present.
I'm still unsure on the tyre strech thing. I ended up with 185/45/15 tyres on my rims, would have liked a lower profile, but they don't exist!
