Steering has become really easy after suspension change?
(In Topic #142001)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.mk1vw.info%2Fimg%2Fhcabby.png)
![Didge in the usergroup ‘Local’ Didge in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Could anyone clear up a steering question for me?
I've changed my suspension on the front and rear with Koni shocks and eibach springs, after I changed it all over the steering has become really easy and not stiff like it was.. It's not such a bad thing really I can do a roundabout with my little finger to be honest and at speed!
When I fitted the suspension I also had some rubbing issue which I managed to fix with the addition of some spacers, also my ride height has changed quite a bit, they are wound all the way up and I will try to wind them down in the morning.
(was gonna see if the suspension settles,as they've only been on a day or so)
But is there any real reason why it was once so stiff and now has become really really easy to turn the wheel? Could it be that because it's so high that their is less stress/friction being transferred through the steering rack because of the angle of the connecting rods to the wheels?
Kind regards,
Didge
I'm so flipping lonely, it's killing me lol at least I can laugh about it!!
rubjonny said
have you had the camber checked? if not thats probably why
Cheers buddy,
I've been reading about how to adjust the camber on the shocks, it's the elongated upper mounting hole on the lower section of the suspension shock.
Are camber settings isolated to each car and suspension setup, or are they universal no matter what the suspension setup? I can't find any information about that from searching, as if the settings are very similar or the same I was going to ask someone to take an image of their settings and I could get them setup to what they have an work from there..
See when I changed the shocks an springs I firstly had no idea that, that was some kind of camber setting infact changing the camber settings did not even come into my mind when changing the suspension.
Still learning eh!
As well as camber, you need the tracking set too. Camber should be done first, then tracking (if you do it the other way round, resetting camber affects tracking). Lowering definitely alters the tracking, and can throw it well out of spec leading to very light steering, very heavy steering, and generally bonkers handling (and tyre wear) until its properly sorted out.
![Avatar](https://i1111.photobucket.com/albums/h478/denisotto/mk1kuf-1.jpg)
![denisotto in the usergroup ‘Local’ denisotto in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Just my opinion and assessment if that.
I went from p slots with 70profile tyres and spongey suspension
To new rims with low pros and new stiffer shocks and springs.
I put it down to simply stiffer setup….
for mine i got some reasonably flat ground and one of those magnetic base camber gauges attached to the wheel hub. To set it I took off 1 wheel and put a jack under the ball joint, set car as close to normal ride height as possible then adjust. repeat for the other side, then get the camber set.
its not going to be 100% perfect unless you can find a totally flat area, but it did the job close enough for me in a pinch.
I've redone the complete front suspension today and tried sorting out the camber as best I can, It still feels really light. I'm going to put this down to the suspension changing the handling and just to be on the safe side I'm going to re-do the pressure in the tyres and get someone in the know down at the garage just to check the balancing of the wheels and tracking.
After ive played with it, because at the end of the day I have to learn how to fix this car myself!
If the garage says it's all fine then I've already learnt how to fit suspension and do the camber/tracking over the last few days
Cheers for your help an advice fellas!
I'll update with what the garage says, just so you know either to never let me near your suspension either that or I might be able to help you's out as a spare hand eh! Lol
Kind regards,
Didge
![Avatar](https://i1108.photobucket.com/albums/h417/chris_hall1/avatar1_zps7e5dd51f.jpg)
![chris-h in the usergroup ‘Old timer’ chris-h in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Mine seemed lots better with the new front suspension, i think the new top mounts helped!
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
![acer in the usergroup ‘Regular’ acer in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20200305_113915.jpg)
![Diesel-dubber in the usergroup ‘Local hero’ Diesel-dubber in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
