Saggy back end
(In Topic #74782)
Guest user
Saggy back end
The car sags really badly when full of fuel and a 9st person+ shopping on the rear seat.
The replacements for my old broken pair came from GSF, is there a difference between front and rear, could front ones have been fitted by mistake?
So what gives?
![tomo320 in the usergroup ‘Old timer’ tomo320 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
paul
![Prowler in the usergroup ‘Old timer’ Prowler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.vwgolfmk1.co.uk%2Fimages%2Froadrunner.jpg)
Guest user
I suspect that GSF supplied tintop rear springs because they have a much softer rating (the cab weighs more)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Did the cab and the tin top have different rate springs?
My Build Thread
![TimHale in the usergroup ‘Local’ TimHale in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Incidently, Jetta and Mk1 Cabrio's share the part number. GPC can supply but at almost the same cost as a VW dealer at approx. ?55 per spring so no advantage there.
I did mention that the springs had been changed after I found that both sides were broken-the bumpstops were replaced as a matter of course.
The cab still handles OK and we drove across the Pyrennes this June through the twistys without drama. However, I prefer not to drag the back end along the deck and it was a bloody waste of money fitting the wrong springs-thanks GSF!
Tim
Control functions:
