removing under rubber for racing purposes???
(In Topic #87434)
![pat in the usergroup ‘Regular’ pat in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Could any one enlighten me with regards to the big ruber piece's which sits underneath on the rear shocks..
Are these just for noise reduction? as ive been told to scrap them and get a 2cm drop from it as its only used for noise reduction when you have a road car, as my car is striped right out noise isnt really a worry..
many thanks again
pat
many thanks again
pat
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Not sure here as im the only one running the Mk1, but it did get said by a guy who has been in the racing scene for long time.
Was wondering if any one else had done the same?
Might give it a blast for next race, but i think a set of yoko's will make a better diference to the big things i got on now! LOL
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I think you would need to replace them with something though or the shock would not sit right in the mount hole (the hole is quite big)?
The race type front top mounts are solid, just with a bearing to allow the struts to turn, so I can't see it causing too much of a problem?
My Build Thread
