Porsche 928 alloys onto my Mk1 Cabrio - What adaptors???
(In Topic #118276)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/badge.jpg)
![jinsta in the usergroup ‘Paid Member’ jinsta in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jinsta in the usergroup ‘Local’ jinsta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
What i need to know is what spacer size in mm i'm gona need to put on?? :dontknow:
Had a quick look today and hub adaptors vary from 20mm spacing upwards. I still want to lower the car so whats best without having any arch mods done?
The rims look like this:
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.928registry.org%2F928-wh32.jpg)
Hopefully once i have polished, i'll end up with something like this (not my car BTW)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fphotos-a.ak.facebook.com%2Fphotos-ak-sf2p%2Fv155%2F212%2F24%2F500553572%2Fn500553572_459696_6312.jpg)
Thanks in advance for your help :wink:
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'93 GTI Sportline
Mk1'82 2.0L 8v
Gota be someone running these??
![:banghead:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__BangHead.gif)
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/snorkler.jpg)
![Tian in the usergroup ‘Local hero’ Tian in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
T
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
![Avatar](https://i532.photobucket.com/albums/ee329/sim0nx/oldspice-1.jpg)
![oldspice in the usergroup ‘Local’ oldspice in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Whats the et on the rims? Should be stamped on the inside near the bolt holes.
Max et on a lowered golf you can run without body work is around 25- 30, so if you work out what the wheels are and minus 28-30, that will give you the width of spacers required. You can run with stretch tyres, or a lower profile, but, as you probablt know this will change the rolling radius of the wheel and will require other compensations!
ie . if the wheels are et 53, then a 20mm spacer will give you an et of 33, ……\i think, but best check with someone else too!!
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
few pics (Cars filthy)
Lost daylight but all 4 on
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
Rims before and after furb, wrapped in 195/40/16 all round
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
![chriseee in the usergroup ‘Local’ chriseee in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
jinsta said
spaced 22mm all round. Yep very close upfront and my test run was litterally only around the block, but seems fine and no scrubbin :roll: Guess when i lower it more will need to receheck clearenece but am gona keep an eye out for a set of 25s to be on the safe side
What was the ride like… firm?
T
The ride was 'firm' on test run, but can't really blame the tyres (yet) as its on crappy hot tuning coilys so the ride quality went out the window ages ago.
I know the tyres wont absorb too much, but wheels go on I'll be dropping new coilys on at the same time - which should hopefully compensate and leave me with a reasonably comfortable ride.
Torn between KW v1s and Weitec GTs - there's price diff between em but been told ride quality's on par…so dunno. Is any1 running either and care to comment?
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
![mr-potato-head82 in the usergroup ‘Regular’ mr-potato-head82 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Went for 20mm spacers for mine, and Hot Tuning coilovers - all are still to be fitted so watch this space!!
Loving the stretch on the rims jinsta - going for Conti Sport 2's on mine.
You gonna be at the AGM jinsta?
Go Hard or Go Home
![davevw67 in the usergroup ‘Regular’ davevw67 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
mr-potato-head82 said
Got the same wheels for my cab, and in the process of polishing em up myself so will let everyone know how I get on.
Will def try and make the show and will hopefully have my tinny on road by then. 20mm was too tight for mine, even with 22mm, thinking 25mm would be optimal for front as the inner rim to strut gap is kinda fractional. My rim width/et details in first posts. I'm actually still not rolling on these yet
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
![scottspur01 in the usergroup ‘Regular’ scottspur01 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
not having mine polished though….too lazy to keep em cleen 8)
Took it for a spin round the block and found a spacer had worked its way loose and the inside of the wheel was rubbing on the coilie!!
After adjusting the ride height so that the locking nut on the coilie was comfortably clear of the tyre, and properly torquing the spacer bolts (doh!), I set the camber so that the rim is away from the coilover. HOWEVER, the camber is definately out (top of the wheel sticks out).
Bearing in mind that I need to have my camber properly adjusted at the garage, I found that 20mm is either VERY close or catching depending on how you have your camber set up.
I think I'm going to go for 25-30mm spacers as I don't want to turn up to the garage and have my camber set up to OE stance and for the inside of the wheel to catch on the coilies.
BTW, very few places will adjust camber if your car is slammed as normal gauges can't be used.
Go Hard or Go Home
