Lowered suspension
(In Topic #78422)
![zod in the usergroup ‘Local’ zod in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Lowered suspension
Hi
I recently purchased a 1983 Mk 1 VW golf GX, which has been lowered by way of lowering caps/strut mounts at the front and lowering springs to the rear.
It looks great parked up but is terrible to drive.
I used to own a bog standard GX. The ride with the standard suspension was fine although the handling could have been a little sharper.
Therefore, I was wondering if anyone knew of a suspension kit, which would give similar ride comfort to the original set up but with a lowered appearance.
I could live with a slightly firmer ride than a standard GX but the way it is at the moment I?m in fear of leaving my exhaust on every speed bump I go over!
I am on a budget and as this is a do-once mod I cannot afford to make the wrong decision so any advice on my options would be greatly appreciated.
Thanks,
Thanks,
![andunp in the usergroup ‘Local’ andunp in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
you could just fit gti springs and shocks this will lower the car about 10mm still giving you a decent ride and at a better ride
Thanks for the tip,
I did consider this but wanted to weigh up other suspension kit options.
If you know more please advise.
