Gearbox linkage adjustmet
(In Topic #77438)
Along with the speaker change, I've finally decided that "Ciaran's Daily Crunch" is not the best way to start the day… (SWM7 know what I mean).
Any tips on gearbox linkage adjustmet?
Looks pretty easy according to Haynes, but doesn't everything? :wink:
You should drink more water.
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
If its warn then you might not be able to adjust it to get it right.
The haynes tells you all you need to know to adjust it. Make soure your in neutral, undo the pinch bolt, remove the plastic cap from the bottom of the gear lever so you can see the bits to align and move the adjust away!
Its a messy job to clean it all up but very satisfying when you've got a perfect change afterwards.
Have to be next week now - bound to rain knowing my luck…
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
Also, I changed the gear oil from typical 80W to Valvoline Synchromesh. I don't know what the UK equilvalent for GM Synchromesh should be.
But the different in the gear grinding was truly stunning.8O
Here is the link to the synchromesh thread on Vortex.
I had a lot of trouble with getting 1st gear to load on cold mornings and even after the warm up, I would have a notchy feeling on 1st and 2nd. Once I put 2L of synchromesh in (combined with the shift linkage bushing refresh), the transmission feels like I have a brand new car. :dontknow: :mrgreen:
This is the upper relay bushing from my car - lots of play and clinking noise. And it had fallen down the shaft and was completely useless.
Life Member
Dan
1664 is 95% water.
Drink more beer?
1664 is 95% water.
Drink more beer?
The EKTA pic is from a MKII? The rubber boot under the gear stick is different on a MK1. These are always ripped and need replacing.
Might as well change but make sure you get a new circlip for the gear stick which holds the spring in place - only pence and you can guarantee the old one will stretch.
Also do the relay lever - metal piece with a rubber ball on the end
Life Member
I understand that things will feel different for a while as my normal 'throw' will have changed a bit but the actual selection is quite difficult. When I select 1st I engage reverse and when going up to 5th, 3rd is found. Is it me not being used to new feel or should more adjustment be made by the garage.
Thanks, Dan
Life Member
I have the brown haynes book, pages141 to 143 seem to cover some of it but your scan may help. Thanks Nigel.
Dan
Life Member
Quick bang it into the Knowledge bin… If you haven't already… its a definate 'for sure'.
Dan
