Wilkos cabby
TLC project
Cam belt kit if you want to change the stud?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/car-service-parts/major-service/timing-belt-kits/?348770288&1&978f48dec2fee9b54c59553d4f4046e793e25576&000332
I use conti belts so I buy a belt and tensioner
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/car-service-parts/major-service/timing-belt/?325440025&1&867869c5ee7cc8a7e6eac597683b148cdbeb08f8&000336
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/car-service-parts/major-service/tensioners-idlers-dampers/?328440040&1&922c7180d65fe8f0fd8e12be11f00419cc118351&000091
Alternator belt size is 950x10 as long as you don't have power steering or air con!
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202770045&1&abd752d4b7d0750374238eb048c8320d06302c5b&000108
You will find it hard to get just 1 HT lead as most places sell a set, Bosch or Beru are good. Try a motor factors?
Air filter it was a popular mod to drill or remove the bottom plastic part of the housing as it was thought more air would make the car go faster but it just sucks in hot dirty air from the engine bay, you really need to get the bottom part of the air box.
Looks like this.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-GTI-AIRBOX-1-6-1-8-K-JET-SCIROCCO-CABRIOLET-UN-DRILLED-/191721339406?hash=item2ca37b7a0e:g:dK8AAOSwHnFVsO~g
Track rod end
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/suspension-and-steering/steering/track-rod-and-track-rod-end/?606550088&1&2d7e78aab9a17bd35c3fdba9a7f05c35fa9e1e23&000349
Fuel filter
Euro car parts does sell the one you need.
There is 2 types and you have the bigger later fuel filter the one listed on there web site is for a Digifant fuel injection system no the K-jet.
Wilkos cabby
http://www.gsfcarparts.com/121vg0070
You may need to unscrew a 17mm extension bolt on the filter as sometimes it comes with one fitted, you will need to renew the washers, 2 are the same size as sump plug washers the other 2 are slightly smaller (I can't remember the size)
Sump plug seal (also needed for oil change)
http://www.gsfcarparts.com/parts/engine-parts/lubrication/sump-plug-seal
http://www.vwspares.co.uk/golf1.php
Or here if not in a rush for parts as not the quickest at delivery, took a week for some of my last order to arrive and still awaiting for other stuff on my order to arrive (30/10/15 ordered) but they are difficult parts for find in this country I'm after. (update… they arrived the next day after posting this, isn't it always the same you mention theses things and they arrive!)
http://www.classic-vw.co.uk/
Last edit: by mark1gls
Quick search of ebay and
http://www.ebay.co.uk/itm/Fuel-Filter-Mann-Filter-WK834-1-/121362825757?hash=item1c41c9c21d:g:3yEAAOxy69JTBBeF
Wilkos cabby
I think I ordered and fitted this one but I will check when I get home later to day.
It did not come with the washers in the picture which was a little annoying!
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_1984/p/car-parts/car-service-parts/regular-service/fuel-filter/?503880019&1&ae258d7a8f7e063d09fe93e75a559a044b5ee8e2&000140
I checked GSF and that has a M14 x 1.5 inner thread?
I use Febi stuff and I ordered this one for mine a could of months ago but you may have different track rods fitted and that's why they don't fit?
Link to what I bought but may be worth a phone call to check the inner thread size.
http://www.vwspares.co.uk/product_info.php?products_id=539
GSF part with the same size thread as the wrong one??
http://www.gsfcarparts.com/436vg0280
The Febi one in the link the same VW part number as fitted from new?
Useful website for part numbers
http://www.partsbase.org/vw/golf-cabriolet-goc-eu-1990-103-steering-gear-track-rod/
Wilkos cabby
It is possible to remove the track rod but it is a bit of a fiddle as there is not much room, you also need a thin spanner to hold the track rod while you loosen the locking nut. When the locking nut is turned up the steering rack the track rod unscrews but you must make sure it goes on at the right length, there is measurement in the Haynes manual.
looking at replacing the colloant hoses and there are two sets by looks of things. a coolant hose kit and ancillary kit my question is what the difference what is the ancillary kit????
thank you very much for your above posts managed to sort out and swap my parts i orded wrongly with you help. ecp have now said if i order more parts to order from pre 80 golf as using my reg will be wrong and they even as a apology they swaped the parts with out charging me the extra 30 pounds i would of owed lol
Wilkos cabby
Last edit: by wilko13
Wilkos cabby
Wilkos cabby
Wilkos cabby
Do you hear the fuel pump run?
What else have you done since it was last running?
Wilkos cabby
Wilkos cabby
