Mk1 Golf 16v - Full Body Restoration - Insta chrisqgolf
![Mk1_Golf_Chriz in the usergroup ‘Local’ Mk1_Golf_Chriz in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk1 Golf Driver - 16V project
Well spent Saturday on the golf up at the shack. Stripped all the suspension, hubs, front wishbones, steering rack, rear beam, fuel tank with the filler neck off the Golf. Its literally just a bare shell now which is great. No nasty rust surprises so far so I'm happy. Forgot to take pictures, but here it is as I was about to tackle it.
![](https://c1.staticflickr.com/5/4282/35100646055_d77ed1cca3_b.jpg)
I took the mounting points off the rear beam and took them home for me to sort out. I bought replacement bolts and a set of replacement washers as the original ones were all covered in thick rust so just seemed a lot easier to just buy replacement parts than refurbing the old stuff, apart from the actual mounts themselves.
![](https://c1.staticflickr.com/5/4213/34969865691_87cb036ef2_b.jpg)
![](https://c1.staticflickr.com/5/4197/34936191982_73ea4a4e53_b.jpg)
Ewww -
![](https://c1.staticflickr.com/5/4223/35060899406_65461b4632_b.jpg)
Thats better, fresh A4 Stainless steel washers and nylon nut.
![](https://c1.staticflickr.com/5/4206/34376029753_ec51b13532_b.jpg)
Love pressing mounts out or in, feels satisfying.
![](https://c1.staticflickr.com/5/4253/34969866131_164aebc656_b.jpg)
![](https://c1.staticflickr.com/5/4234/34713854080_4ef92c3d49_b.jpg)
Wire brushed off all the loose rust on the mounts and chucked them in the box of parts for powder coating.
Also stripped my gear stick and replaced the ball mount. Nice easy job.
![](https://c1.staticflickr.com/5/4265/34256179774_dc5b79b97e_b.jpg)
![](https://c1.staticflickr.com/5/4206/34290196733_c7f65f5645_b.jpg)
![](https://c1.staticflickr.com/5/4199/34256180244_c659407411_b.jpg)
clean and regrease arm
![](https://c1.staticflickr.com/5/4289/34290196283_3eb076d0f4_b.jpg)
Then back together
![](https://c1.staticflickr.com/5/4209/34713382300_80abc87525_b.jpg)
![](https://c1.staticflickr.com/5/4270/34969417821_0511478b2d_b.jpg)
![](https://c1.staticflickr.com/5/4258/34935805082_1c8d76bdb8_b.jpg)
Also mounted my alternator back on the engine after torquing up the clutched pulley wheel. Although I think I might get a smaller belt as It's on the limit of its adjustment already and after it relaxes a lil once its in and running, its bound to start slipping.
![](https://c1.staticflickr.com/5/4236/35060899166_880fc43491_b.jpg)
![](https://c1.staticflickr.com/5/4197/34290628643_1d5513f494_b.jpg)
![](https://c1.staticflickr.com/5/4198/34714527490_4b3636f2b7_b.jpg)
![](https://c1.staticflickr.com/5/4290/34387934674_3006a8a629_b.jpg)
![](https://c1.staticflickr.com/5/4280/35065967832_e8b086ee4e_b.jpg)
All thats left now is the front window, steering column, a bit of dash wiring loom, drivers wing and the headlining, along with the doors but cant take them off until the cars on a trolley and off the ramp.
I've been chatting with Adam from Noath Engineering about making some threaded inserts to bolt my rose jointed TRE on to the hub. This will allow me to fit them on the underside of the hub without having to drill out the taper on the mounting point. Adam is also going to match these up with the bottom ball joint extenders he has done, so they'll be exactly the same size difference, which in return will keep the whole geometry the same, ideal! I believe hes now going to offer this as part of a kit to sell as an option along side his bottom ball joints. :thumbup: Excuse the 'kids' drawing.
![](https://c1.staticflickr.com/5/4288/34425475443_b0c1ddd942_b.jpg)
![](https://c1.staticflickr.com/5/4257/34798878040_dd508ee10b_b.jpg)
Whilst I was there had a little perv on my wheels
![](https://c1.staticflickr.com/5/4285/35192633466_f904b9172d_b.jpg)
And then decided to go ahead and braid all of my HT leads and heat shrink the ends to give it a finish I was happy with. Will probably make up a heat shield off the back of the head to protect them from the heat off the exhaust manifold, even though the braid is meant to withstand high heats.
![](https://c1.staticflickr.com/5/4254/35231636995_c0621652e5_b.jpg)
![](https://c1.staticflickr.com/5/4251/34422764603_dfdfda0873_b.jpg)
Also this lil treat turned up in the post
![](https://c1.staticflickr.com/5/4196/35271265116_3ae93146d0_b.jpg)
![](https://c1.staticflickr.com/5/4282/35181643521_4467149f28_b.jpg)
Oh and just having a little perv on this
![](https://c1.staticflickr.com/5/4288/35311575725_7a12891e75_b.jpg)
![](https://c1.staticflickr.com/5/4280/35399880805_d3cc70f733_b.jpg)
![](https://c1.staticflickr.com/5/4245/34590664463_ccb8f24e48_b.jpg)
![](https://c1.staticflickr.com/5/4242/35360838456_b6867a0dbe_b.jpg)
No nasty surprises under the windscreen, which was nice.
![](https://i.imgur.com/YgpT8bT.png)
![](https://c1.staticflickr.com/5/4269/35360838466_aa528673c6_b.jpg)
![](https://c1.staticflickr.com/5/4262/35233613012_d17024e535_b.jpg)
Pulled the rest of the wiring out, headliner and steering column.
![](https://c1.staticflickr.com/5/4257/34590664883_f29a6bf16a_b.jpg)
Then Dave showed me how to remove some mounts in the engine bay, simple when you know how.
![](https://c1.staticflickr.com/5/4257/35013005560_e3d283acbc_b.jpg)
![](https://c1.staticflickr.com/5/4226/35013005090_4800fda226_b.jpg)
Also removed this odd mount/brace? No clue what it is or does? anyone?
![](https://c1.staticflickr.com/5/4262/35233615702_74fe9eb835_b.jpg)
![](https://c1.staticflickr.com/5/4215/35399882245_b2a997ae03_b.jpg)
![](https://c1.staticflickr.com/5/4233/34590666193_7251080425_b.jpg)
Battery tray out
![](https://c1.staticflickr.com/5/4227/35013004850_50326e93c0_b.jpg)
![](https://c1.staticflickr.com/5/4205/35270554761_e87484ac8c_b.jpg)
![](https://c1.staticflickr.com/5/4280/35233616002_8d500f98d1_b.jpg)
Then made a plan for welding up unwanted holes -
![](https://c1.staticflickr.com/5/4224/34559101194_cb8fe1b885_b.jpg)
Also John has just finished welding up and smoothing my lips so they're all ding free, cheers mate :thumbup: Now to get them to the polishers.
![](https://c1.staticflickr.com/5/4219/35272011501_f744d40991_b.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/DSC04200%20%282%29.jpg)
Regional Host Wales
![sam1008 in the usergroup ‘Paid Member’ sam1008 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![sam1008 in the usergroup ‘Regional Hosts’ sam1008 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![sam1008 in the usergroup ‘Local’ sam1008 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![pazwaa in the usergroup ‘Old timer’ pazwaa in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Matt
Adams been having some fun with my wheels
![](https://farm5.staticflickr.com/4277/35853485605_a15db17884_b.jpg)
![](https://farm5.staticflickr.com/4282/35043831203_64b264655d_b.jpg)
![](https://farm5.staticflickr.com/4258/35684281712_f13db03388_b.jpg)
![](https://farm5.staticflickr.com/4239/35853489405_d098eb8c94_b.jpg)
![](https://farm5.staticflickr.com/4233/35853485005_2799bd0357_b.jpg)
They're now with John getting some of the final metal work touches done, then will be all ready for powder coating.
Adam has also finished my track rod end flip pins, these look bloody brilliant :thumbup: You can now buy these from Adam at Noath Precision
![](https://farm5.staticflickr.com/4257/35812811836_c89918d57c_b.jpg)
![](https://farm5.staticflickr.com/4213/35684282632_1daaf83933_b.jpg)
![](https://farm5.staticflickr.com/4286/35721390151_e2858f30b4_b.jpg)
![](https://farm5.staticflickr.com/4278/35013152114_5a5ae25756_b.jpg)
![](https://farm5.staticflickr.com/4290/35465508850_41908383db_b.jpg)
Now onto abit of the shell work, spent a couple of Saturday mornings up the Shack. This picture shows the engine bay as it was. I also placed in my speedo cable to test out a new rooting which leads it straight to the pick up point on the gearbox.
![](https://farm5.staticflickr.com/4230/35721385671_72b836d926_b.jpg)
Nasty weld, thats coming straight out.
![](https://farm5.staticflickr.com/4277/35812807736_735f5b9a0f_b.jpg)
![](https://farm5.staticflickr.com/4282/35043828933_23135d0315_b.jpg)
Then cut square holes onto all the holes I want to make plates for
![](https://farm5.staticflickr.com/4216/35013147814_b3e6e633d3_b.jpg)
![](https://farm5.staticflickr.com/4206/35465511060_3283d75637_b.jpg)
![](https://farm5.staticflickr.com/4259/35721387031_029a22cb22_b.jpg)
Slow but steady -
![](https://farm5.staticflickr.com/4281/35043832323_7b0062dc34_b.jpg)
![Lhasa2008 in the usergroup ‘Paid Member’ Lhasa2008 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Lhasa2008 in the usergroup ‘Old timer’ Lhasa2008 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Love those track rod end flip pins too!
![BirchyB0y in the usergroup ‘Local’ BirchyB0y in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Take my hat off to you, will continue to follow and look forward to seeing the completed car on the 30th at the AGM…!!!!!
Well done Sir, credit to your work and passion for the MK1.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Untitled.png)
![JoeHayes in the usergroup ‘Paid Member’ JoeHayes in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![JoeHayes in the usergroup ‘Local’ JoeHayes in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
Well Dave put a welder in my hand and told me to weld up all the holes I created. I've never really welded before, but Dave showed me the way - quite happy with how I did. Welds, welds and many welds later.
![](https://farm5.staticflickr.com/4292/35876099041_0ecc7095ed_b.jpg)
![](https://farm5.staticflickr.com/4294/35876013491_929c91d780_b.jpg)
![](https://farm5.staticflickr.com/4326/35838513262_bb70154f65_b.jpg)
![](https://farm5.staticflickr.com/4328/35968146466_06fca22a6c_b.jpg)
Removed these two
![](https://farm5.staticflickr.com/4328/36009760845_6e9c9812ec_b.jpg)
![](https://farm5.staticflickr.com/4305/35620108130_8245421c13_b.jpg)
Scrapped sealant off -
![](https://farm5.staticflickr.com/4302/35838597882_e41cf4a9c6_b.jpg)
![](https://farm5.staticflickr.com/4321/35967809436_8019b1ff73_b.jpg)
![](https://farm5.staticflickr.com/4310/36009758985_2d2a85c27d_b.jpg)
![](https://farm5.staticflickr.com/4323/35169911784_b37c44d281_b.jpg)
And as it is at the moment -
![](https://farm5.staticflickr.com/4296/35620461590_461e30c868_b.jpg)
![](https://farm5.staticflickr.com/4302/36009211695_e6e7aa1716_b.jpg)
Also John has been working away on my wheels. Made a nice lil groove for the center caps to locate in -
![](https://farm5.staticflickr.com/4324/35198490853_15728ed85e_b.jpg)
![](https://farm5.staticflickr.com/4328/35620102780_701b4e5b5f_b.jpg)
Looking smart
![](https://farm5.staticflickr.com/4306/35838509822_47222a7d3b_b.jpg)
And just sent all these inserts off to be anodised -
![](https://farm5.staticflickr.com/4312/36009731605_e2d537b2f2_b.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/a0baa6c9894dc57b7e44c44f8834c9ed.jpg)
![Fausto in the usergroup ‘Old timer’ Fausto in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/6J7A7209-30.jpg)
![scottyr1 in the usergroup ‘Paid Member’ scottyr1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![scottyr1 in the usergroup ‘Old timer’ scottyr1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
How do you do the Instagram link you have? Would like to do that
I spent a whole day cleaning today… takes much longer than you think. Still not even done!
![](https://farm5.staticflickr.com/4323/35860058902_00a69ef596_b.jpg)
![](https://farm5.staticflickr.com/4296/35897393541_0ff8cf4643_b.jpg)
![](https://farm5.staticflickr.com/4319/35220907793_1c69e2aa79_b.jpg)
![](https://farm5.staticflickr.com/4319/35989521326_11b6273207_b.jpg)
![](https://farm5.staticflickr.com/4321/36031236045_d38829c53c_b.jpg)
![](https://farm5.staticflickr.com/4306/35897393831_9b2e09f715_b.jpg)
![](https://farm5.staticflickr.com/4329/36031235995_406dc98759_b.jpg)
![FXTURE in the usergroup ‘Paid Member’ FXTURE in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![FXTURE in the usergroup ‘Local’ FXTURE in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Gra
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
Wheels looking lovely
Matt
Front wings paint stripped and discovered a previous dent that had been repaired..
![](https://farm5.staticflickr.com/4407/37394578702_b07e4c23d1_b.jpg)
![](https://farm5.staticflickr.com/4423/37394570722_590b7edff5_b.jpg)
![](https://farm5.staticflickr.com/4356/37168281230_a586ba24f0_b.jpg)
![](https://farm5.staticflickr.com/4405/37394572682_139a44b3eb_b.jpg)
![](https://farm5.staticflickr.com/4479/37394573562_79964f609d_b.jpg)
![](https://farm5.staticflickr.com/4344/37394571242_afdac2ea86_b.jpg)
![](https://farm5.staticflickr.com/4457/37168276270_28845b9960_b.jpg)
Aerial hole and small rust patch welded in -
![](https://farm5.staticflickr.com/4381/37168275660_6bf6ce4c7e_b.jpg)
![](https://farm5.staticflickr.com/4483/37534302551_eed0a3f4c4_b.jpg)
![](https://farm5.staticflickr.com/4433/37168271890_c07f87f21f_b.jpg)
![](https://farm5.staticflickr.com/4464/37534303591_ea9bb5a31a_b.jpg)
Boot lid paint stripped
![](https://farm5.staticflickr.com/4490/37168281640_94d3b7c95a_b.jpg)
![](https://farm5.staticflickr.com/4410/37168273100_6ded04296a_b.jpg)
Wiper and badge holes welded over
![](https://farm5.staticflickr.com/4410/37168272310_be8c4b5c19_b.jpg)
![](https://farm5.staticflickr.com/4491/37275831100_d5c29bfb12_b.jpg)
Body now up at the main shop
![](https://farm5.staticflickr.com/4414/37168271120_20f4527cb6_b.jpg)
Panels off
![](https://farm5.staticflickr.com/4338/37168270870_5f5e54fc78_b.jpg)
Made a start on taking all this muck off :thumbdown:
![](https://farm5.staticflickr.com/4379/36754954503_81192ee1ae_b.jpg)
![](https://farm5.staticflickr.com/4483/36754954013_186eb95103_b.jpg)
![](https://farm5.staticflickr.com/4394/36754950683_a2730fbee6_b.jpg)
![](https://farm5.staticflickr.com/4510/37394555982_0e595b868c_b.jpg)
![](https://farm5.staticflickr.com/4489/23681904648_8d57f89f69_b.jpg)
![](https://farm5.staticflickr.com/4445/36885062423_81cb144d28_b.jpg)
And still haven't finished it!
Dave aka RestoShack has spent the week working on my rear arches :thumbup:
![](https://farm5.staticflickr.com/4495/36865855283_ba8bf3bc72_b.jpg)
![](https://farm5.staticflickr.com/4478/23682727398_4a8c507b6b_b.jpg)
![](https://farm5.staticflickr.com/4482/36754955623_b21d1f465c_b.jpg)
![](https://farm5.staticflickr.com/4490/36754955353_661b10d03e_b.jpg)
Half rear tub on passenger side
![](https://farm5.staticflickr.com/4405/36754953043_32ec4e4f4f_b.jpg)
But not before fixing up the bottom inner tub
![](https://farm5.staticflickr.com/4442/36754951983_d211eba7c1_b.jpg)
![](https://farm5.staticflickr.com/4350/36754951793_f9b075f322_b.jpg)
Fixed an old dent
![](https://farm5.staticflickr.com/4469/36810587083_07e295620d_b.jpg)
![](https://farm5.staticflickr.com/4481/37432398016_56918dbf4c_b.jpg)
And new tub and arch on
![](https://farm5.staticflickr.com/4468/37432398006_52d61d5699_b.jpg)
![](https://farm5.staticflickr.com/4497/37504040492_06576234d1_b.jpg)
![](https://farm5.staticflickr.com/4512/37432397776_8d163f8715_b.jpg)
I couldnt resist to not have a look under this patch welded over rust :cry:
![](https://farm5.staticflickr.com/4494/36754943793_1eb394db21_b.jpg)
![](https://farm5.staticflickr.com/4437/37168263140_81f01102eb_b.jpg)
![](https://farm5.staticflickr.com/4388/37168262420_8e2b6b3d85_b.jpg)
![](https://farm5.staticflickr.com/4403/37168261610_3a8401e713_b.jpg)
Dave then fixed this random little hole
![](https://farm5.staticflickr.com/4463/37504028942_1cf9955c3a_b.jpg)
![](https://farm5.staticflickr.com/4503/37504030312_3355631158_b.jpg)
![](https://farm5.staticflickr.com/4471/23681901618_f30629c670_b.jpg)
Then he cracked on and fixed my fuel filler hole
![](https://farm5.staticflickr.com/4451/37504028002_802a5c1c7d_b.jpg)
![](https://farm5.staticflickr.com/4514/37275836920_a505270782_b.jpg)
![](https://farm5.staticflickr.com/4493/37275836520_18b2b975ec_b.jpg)
![](https://farm5.staticflickr.com/4503/36885062583_fcf73f9882_b.jpg)
![](https://farm5.staticflickr.com/4474/37275830330_c75837c961_b.jpg)
Dave then made a start on the drivers rear tub and arch. This side was bad, needed a full rear tub
![](https://farm5.staticflickr.com/4513/37504038572_d0ea71d9f6_b.jpg)
![](https://farm5.staticflickr.com/4486/37504036572_594b4962f8_b.jpg)
![](https://farm5.staticflickr.com/4474/23682734748_6329bd2468_b.jpg)
![](https://farm5.staticflickr.com/4472/36865045723_e099de357e_b.jpg)
![](https://farm5.staticflickr.com/4446/37487232956_e9799981df_b.jpg)
![](https://farm5.staticflickr.com/4464/37487232436_4dec852165_b.jpg)
Then gave the inner quarter a good clean
![](https://farm5.staticflickr.com/4449/37534301871_10fde4d437_b.jpg)
Now ready for weld
![](https://farm5.staticflickr.com/4484/37275836370_57af56625d_b.jpg)
Then packed up and put away until he gets another chance to work on it.
![](https://farm5.staticflickr.com/4460/23681903448_aaa2df15d9_b.jpg)
Dave also completed the triangular rear beam modification setup.
![](https://farm5.staticflickr.com/4403/37394555332_d69a6e09ff_b.jpg)
![](https://farm5.staticflickr.com/4483/37425326301_0bce4e5877_b.jpg)
![](https://farm5.staticflickr.com/4421/37394553552_f0163477c8_b.jpg)
![](https://farm5.staticflickr.com/4359/37168257200_4a4d4f7c78_b.jpg)
![](https://farm5.staticflickr.com/4487/37432398276_73500abe2a_b.jpg)
![](https://farm5.staticflickr.com/4466/36810586953_4737f0806b_b.jpg)
Also Rob from Resto Shack has painted my new fuel tank, now time to swap over all the bits from my old one to the fresh new GTi tank
![](https://farm5.staticflickr.com/4492/36885061943_9648c852d8_b.jpg)
Also John has nearly finished with my wheels, hes welded in the missing tabs and got them all straight and pretty again.
![](https://farm5.staticflickr.com/4439/37394566332_bca5e8955e_b.jpg)
![](https://farm5.staticflickr.com/4464/37168274470_d78ecca8ca_b.jpg)
![](https://farm5.staticflickr.com/4421/37168273920_82592f473f_b.jpg)
![](https://farm5.staticflickr.com/4413/37168271330_b3024d03d7_b.jpg)
![Hurtig in the usergroup ‘Local’ Hurtig in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
Love the wheels - they will be sick!
Normally i like engines OEM an in the original color scheme, but I really like the black theme on your engine. It really blends perfectly. It will look absolutely awesome in the bay.
Biggest respect so far - look forward to see the finished build
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
1982 - Mk1 Golf 2.0 AGG 8v - 158 HP / 202 NM
_________________________________________
