82 mars red GTI
The little GTI, 82 mars red mk1
First off I bolted wing onto the car with arch liner screwed in place to get the positions to where the clips that hold the arch liner to the body goes, marked points with a pen then drilled a hole with a 7mm drill bit and used as small squre file to file into a square. Had to do this as 3 out of the 4 points had rotted away.
Then I cut off arch then cut the inner arch back to good metal and tac'd inner arch on messed with it to get it to fit right then welded it on properly.
And then the inner sill went on.
And battery tray on too.
Also painted my rear caliper carriers and battery clamp.
Keep it up!
piccys-
gauges
caliper carriers and stub axles
sills, genuine vs non genuine (tops the genuine one)
Throttle body and a template of what needs to be ground off the manifold.
spare wheel tub repair
I saw a crinkly peanut tomorrow
Been buying bits for it again got a radiator fan, dash clock surround thingy, samco hoses and some plastic grilles that go behind the front bumper.
Took the fan apart, cleaned the blades up and painted the motor and the put it back together and fitted it to the cowling. gonna paint the red grille trim next since I can rub them down in the warm. :mrgreen:
sill trial fitting + spare wheel tub
fan motor + fan fitted to cowling
bits I got
