"TAG" - 1983 Campaign restoration blog
![cdgthreesalmons in the usergroup ‘Paid Member’ cdgthreesalmons in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![cdgthreesalmons in the usergroup ‘Old timer’ cdgthreesalmons in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![DSCN1437.JPG DSCN1437.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659720/uploads/attachments/5fc3ae8830175.jpg)
![DSCN1448.JPG DSCN1448.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659723/uploads/attachments/5fc3ae8a52bbf.jpg)
They certainly needed attention!
![DSCN1476.JPG DSCN1476.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659900/uploads/attachments/5fc3af3a16c31.jpg)
![DSCN1478.JPG DSCN1478.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659903/uploads/attachments/5fc3af3e4d130.jpg)
Front wishbones were badly corroded and had clearly had a lot of major knocks - they were far from true! so needed replacing. Same with the rear wishbone rubbers - badly deteriorated
![DSCN1480.JPG DSCN1480.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659905/uploads/attachments/5fc3af40b0400.jpg)
![DSCN1481.JPG DSCN1481.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606659907/uploads/attachments/5fc3af42bccab.jpg)
![DSCN1514.JPG DSCN1514.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660054/uploads/attachments/5fc3afd54756d.jpg)
![DSCN1515.JPG DSCN1515.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660059/uploads/attachments/5fc3afda37cd0.jpg)
I found that I could do this using a large vice. Plenty of lubrication required.
![DSCN1516.JPG DSCN1516.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660063/uploads/attachments/5fc3afdde6ac4.jpg)
![DSCN1517.JPG DSCN1517.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660067/uploads/attachments/5fc3afe1e2a05.jpg)
Once part way through I used a large diameter socket to enable the end of the bush to "pop" through.
![DSCN1518.JPG DSCN1518.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660070/uploads/attachments/5fc3afe54939a.jpg)
Job done!
![DSCN1519.JPG DSCN1519.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660073/uploads/attachments/5fc3afe89cde4.jpg)
![DSCN1514.JPG DSCN1514.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660058/uploads/attachments/5fc3afd8d1c2e.jpg)
![DSCN1515.JPG DSCN1515.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660061/uploads/attachments/5fc3afdcabe5b.jpg)
![DSCN1516.JPG DSCN1516.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660065/uploads/attachments/5fc3afe0715b1.jpg)
![DSCN1517.JPG DSCN1517.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660069/uploads/attachments/5fc3afe4b331f.jpg)
![DSCN1518.JPG DSCN1518.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660073/uploads/attachments/5fc3afe84a8bb.jpg)
Job done!
![DSCN1519.JPG DSCN1519.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660079/uploads/attachments/5fc3afedd6469.jpg)
![DSCN1572.JPG DSCN1572.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660150/uploads/attachments/5fc3b0350a07f.jpg)
![DSCN1573.JPG DSCN1573.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660743/uploads/attachments/5fc3b28569a07.jpg)
![DSCN1574.JPG DSCN1574.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660747/uploads/attachments/5fc3b28a3dff8.jpg)
New top mounts
![DSCN1579.JPG DSCN1579.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660750/uploads/attachments/5fc3b28dd3a03.jpg)
I have read some recent debates on the Facebook forum regarding movement in new top mounts. As can be seen clearly in the photo below, when the new spacer sleeve is fitted in to the new top mount - the spacer sleeve is proud of the mount. This will therefore allow a certain amount of movement once the top washer and nut is torqued up. I have to assume this is correct - as others have witnessed. Without this movement the bush in the strut would not have any movement and any movement from the strut would cause the engine compartment metal to flex. I have seen some people grind this sleeve flush with the mount and others pack it with washers to take up the slack. I am fitting these brand new parts as the manuals/parts list shows.
![DSCN1581.JPG DSCN1581.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660754/uploads/attachments/5fc3b29171ed2.jpg)
Tighening the top nut is quite tricky but with a 22mm ring spanner and 7mm hex bit it is okay.
![DSCN1585.JPG DSCN1585.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660758/uploads/attachments/5fc3b294db060.jpg)
![DSCN1583.JPG DSCN1583.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660762/uploads/attachments/5fc3b2996a747.jpg)
Finally I managed to salvage the original VAG sticker from the front struts that reattached after cleaning the struts.
![DSCN1588.JPG DSCN1588.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606660766/uploads/attachments/5fc3b29ccc2af.jpg)
After removing the calliper I removed the calliper carrier.
![DSCN1503.JPG DSCN1503.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661233/uploads/attachments/5fc3b4700eeb5.jpg)
![DSCN1532.JPG DSCN1532.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661237/uploads/attachments/5fc3b4747bede.jpg)
The callipers were now ready to strip down.
![DSCN1533.JPG DSCN1533.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661241/uploads/attachments/5fc3b477f0a6a.jpg)
![DSCN1534.JPG DSCN1534.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661245/uploads/attachments/5fc3b47c3f645.jpg)
After removing the flexi brake line - I used a compressor and airline to "pop" the brake pistons out. I placed a thick cloth in front of the piston to prevent damage to the calliper. Only a very small amount of air was required to get them out.
![DSCN1538.JPG DSCN1538.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661248/uploads/attachments/5fc3b47f96c32.jpg)
Not exactly in perfect clean condition!
![DSCN1539.JPG DSCN1539.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661252/uploads/attachments/5fc3b48347074.jpg)
What I found in behind the piston was quite shocking. Considering it should be spotlessly clean the amount of gunge and flakes of rust was considerable!
![DSCN1541.JPG DSCN1541.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661257/uploads/attachments/5fc3b4881d4c8.jpg)
![DSCN1543.JPG DSCN1543.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661260/uploads/attachments/5fc3b48bb64a6.jpg)
The dust seal was eased out next.
![DSCN1542.JPG DSCN1542.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661265/uploads/attachments/5fc3b4909e96f.jpg)
And finally the main piston seal
![DSCN1547.JPG DSCN1547.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661269/uploads/attachments/5fc3b4948eede.jpg)
One stripped down brake calliper.
![DSCN1548.JPG DSCN1548.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661273/uploads/attachments/5fc3b4981dfea.jpg)
![DSCN1551.JPG DSCN1551.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661482/uploads/attachments/5fc3b568db677.jpg)
I didn't want to immerse the callipers in rust treatment for fear of damaging the cylinder linings. I therefore covered them in Bilt Hamber Deox Gel - that is applied in a thick layer - but not in the cylinder.
![DSCN1553.JPG DSCN1553.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661485/uploads/attachments/5fc3b56c61f11.jpg)
These were then wrapped in clingfilm to keep the gel from drying out.
![DSCN1554.JPG DSCN1554.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661489/uploads/attachments/5fc3b56fe725e.jpg)
After several sessions of adding more gel/washing they came up remarkably well.
![DSCN1555.JPG DSCN1555.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661492/uploads/attachments/5fc3b573c06f2.jpg)
![DSCN1556.JPG DSCN1556.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661497/uploads/attachments/5fc3b5781a960.jpg)
I chose to use Foliatec brake caliper paint. It was an excellent kit including everything you needed - gloves, wire brush, paintbrush, stirring stick, paint and hardener.
https://www.demon-tweeks.com/foliatec-brake-caliper-paint-and-engine-lacquer-243118/?sku=FOL2160&istCompanyId=a2904180-3a7d-4e56-b876-cf81c9512180&istFeedId=6fbc4b04-fd28-4ce1-8513-835c8f118690&istItemId=wptpiipxa&istBid=t&gclid=EAIaIQobChMI_YrczoCo7QIVT9PtCh1h4Q4GEAQYASABEgKlN_D_BwE&gclsrc=aw.ds
The hardener is poured into the paint tin and mixed - this gives you several workable hours before it cures. Having masked the areas I didn't want painted like the pad rubbing strips and especially the cylinder - I used a "dabbing" method of applying the paint rather than painting prevented brush marks. Results appear good - time will tell if it lasts.
![DSCN1564.JPG DSCN1564.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661748/uploads/attachments/5fc3b673463d9.jpg)
![DSCN1565.JPG DSCN1565.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606661752/uploads/attachments/5fc3b67717836.jpg)
http://biggred.co.uk/brake-caliper-piston-repair-kit
This included the new seals, new piston, silicon grease, and new bolt rubbers.
![DSCN1566.JPG DSCN1566.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662572/uploads/attachments/5fc3b9aabcb0f.jpg)
![DSCN1567.JPG DSCN1567.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662575/uploads/attachments/5fc3b9ae9aa46.jpg)
First fit the new piston seal into the cylinder - nice and easy. Then slightly more tricky to fit the new piston dust seal. Having watched online videos I found the easiest method was to push the seal right over the piston - to the far end, then gently (and a bit fiddly) ease the outer part of the seal into the groove in the cylinder mouth. With the aid of the silicone grease I could then gently push the piston into the cylinder.
![DSCN1568.JPG DSCN1568.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662579/uploads/attachments/5fc3b9b287450.jpg)
The push in the new bolt rubbers,
![DSCN1569.JPG DSCN1569.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662583/uploads/attachments/5fc3b9b62c56c.jpg)
And reattach the calliper housing to the calliper,
![DSCN1570.JPG DSCN1570.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662587/uploads/attachments/5fc3b9b9e8554.jpg)
New bleed nipple - ready to go!!!
![DSCN1571.JPG DSCN1571.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606662590/uploads/attachments/5fc3b9bd9ea68.jpg)
This is an excellent video on the process.
https://www.youtube.com/watch?v=iCMpI7Bl1Bc
![DSCN1487.JPG DSCN1487.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663083/uploads/attachments/5fc3bbaa6fc47.jpg)
![DSCN1508.JPG DSCN1508.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663085/uploads/attachments/5fc3bbacbb0a6.jpg)
![DSCN1510.JPG DSCN1510.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663089/uploads/attachments/5fc3bbb064d5f.jpg)
There was no way I could get the front hubs out of the front carriers. The bearings were just too tight.
I therefore took them along to my friendly local garage and for £10 they pressed out the front hubs and pressed out the old front bearings.
![DSCN1522.JPG DSCN1522.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663093/uploads/attachments/5fc3bbb3cc6f6.jpg)
![DSCN1523.JPG DSCN1523.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663097/uploads/attachments/5fc3bbb7c9814.jpg)
Removing the old rusty/partly rotten brake splash guards was fun!!! All but one bolt came out easily after applying plenty of heat - but one inevitably broke off! I had to drill this out and re-tap the hole.
![DSCN1524.JPG DSCN1524.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663101/uploads/attachments/5fc3bbbc0651b.jpg)
![DSCN1528.JPG DSCN1528.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663104/uploads/attachments/5fc3bbbfa0376.jpg)
I put the hub carriers into a solution of hot Bilt Hamber Deox solution and used an aquarium heater to keep it hot.
![DSCN1530.JPG DSCN1530.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663108/uploads/attachments/5fc3bbc2f021e.jpg)
Great results!
![DSCN1536.JPG DSCN1536.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663111/uploads/attachments/5fc3bbc676f56.jpg)
These were then painted in Rustbuster Epoxy
![DSCN1589.JPG DSCN1589.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663115/uploads/attachments/5fc3bbca48827.jpg)
![DSCN1590.JPG DSCN1590.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663119/uploads/attachments/5fc3bbce142b2.jpg)
Now to reassemble
![DSCN1591.JPG DSCN1591.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663122/uploads/attachments/5fc3bbd1bdc8c.jpg)
![DSCN1592.JPG DSCN1592.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663126/uploads/attachments/5fc3bbd5a2f32.jpg)
The returned to my local garage who for £20 pressed in new front wheel bearings and new front wheel hubs.
![DSCN1598.JPG DSCN1598.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663130/uploads/attachments/5fc3bbd96ee19.jpg)
![DSCN1599.JPG DSCN1599.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1606663134/uploads/attachments/5fc3bbdd56148.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/NK785B-1-1.jpg)
![Malcolm in the usergroup ‘Paid Member’ Malcolm in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Malcolm in the usergroup ‘Old timer’ Malcolm in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Sent from my H3113 using Tapatalk
![DSCN1593.JPG DSCN1593.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607860186/uploads/attachments/5fd5ffd9246a4.jpg)
Using a soldering iron I could melt these into place as repair sections - then drill a new hold for the speed nut. Also used the soldering iron to melt over the odd holes. Not the neatest but fully repaired.
![DSCN1595.JPG DSCN1595.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607860190/uploads/attachments/5fd5ffdd17bbe.jpg)
![DSCN1609.JPG DSCN1609.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865147/uploads/attachments/5fd61339b57b6.jpg)
..and front wheel hub carrier
![DSCN1611.JPG DSCN1611.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865150/uploads/attachments/5fd6133d9de5c.jpg)
![DSCN1607.JPG DSCN1607.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865217/uploads/attachments/5fd6137fd2b9e.jpg)
New Brembo discs…
![DSCN1613.JPG DSCN1613.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865220/uploads/attachments/5fd613838e95a.jpg)
![DSCN1614.JPG DSCN1614.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865320/uploads/attachments/5fd613e78ee3a.jpg)
Calliper carrier….
![DSCN1615.JPG DSCN1615.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865323/uploads/attachments/5fd613ea74dcd.jpg)
![DSCN1616.JPG DSCN1616.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865327/uploads/attachments/5fd613ede6686.jpg)
…and finally the brake callipers & new Brembo pads and new flexi brake pipe
![DSCN1617.JPG DSCN1617.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865330/uploads/attachments/5fd613f13a314.jpg)
![DSCN1618.JPG DSCN1618.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865333/uploads/attachments/5fd613f41ee9a.jpg)
![DSCN1619.JPG DSCN1619.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865533/uploads/attachments/5fd614bbdd0ac.jpg)
![DSCN1621.JPG DSCN1621.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865536/uploads/attachments/5fd614bec6f07.jpg)
A nice clean underneath - the dark areas are the Bilt Hamber Dynax S50 rust treatment - also used plenty of the clear Bilt Hamber UC rust treatment
![DSCN1622.JPG DSCN1622.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865539/uploads/attachments/5fd614c225b83.jpg)
![DR1BnPsWAAAo-Xw.jpg DR1BnPsWAAAo-Xw.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1607865704/uploads/attachments/5fd61568288b0.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Reading restoration threads is always a pleasure.
A. Merry Christmas to you as well!
