"TAG" - 1983 Campaign restoration blog
They fit between the front quarter light and wind down window. At the bottom they are held, in my case, by a pop rivet. Water had gathered in the bottom of the door due to a damaged plastic membrane and caused inevitable rot.
I cleaned up the metal and then cut out the rot.
The created new sections. Difficult as the guide is like a girder section. I could fold one section then weld the other to it to form the shape.
Once the new section was formed I could weld it to the existing clean metal. Trying to maintain the curve of the guide as best as possible.
Finally treated with full POR 15 treatments, then some rust proofing seam sealer before etch primer and top coat. They dont look too bad considering the state they were in!
Air flow meter before:
and after:
Also cleaned up and electro-plated the catches
and cleaned and plated all sunroof fittings:
Hear stripped
Porting work
Triple valve cut
New guides
New guides
Rebuilt head
Painted block
Painted block
The gearbox restorer found that the pin had been welded into the diff housing??????
Welded diff pin
Welded diff pin
Diff rivets being drilled out to replace with bolts
That silver looks stunning.
