83 Gti set to get full resto
My 83 Gti set to get full restoration
Melteddrummer said
It's a new one mate, I bought it from a member when I first joined the forum. Not sure where he bought it from though.
Where did you buy yours from mate? and is your outer rim all one piece or is it in sections like mine?
Andy, mine came direct from Werk 34 in Germany, although it looks like a copy. Not a good fit though and will need some attention when I get there.
Think I might have to remove it again though as I forgot to bare the metal and zinc prime It took me a couple of hours to sort it out after work.
earlier in the week I sorted the back half of the floor out and zinc primered the lot
Here's how the wheel well is held together, not very straight!!
So, I broke the spot welds and used a ratchet strap to pull it in straight as the well was tapering out at the top making it tighter the further it went through the hole I had to repeat this in three places around the wheel well.
After all this work it still took a bit of persuading into position but she's in at last
The fit isn't perfect in the recess inside the boot and it's overlapping in a couple of areas but once it's covered with seam sealer you wont even know.
I'll be back to finish it off tomorrow, then it will be seam sealer and epoxy time!!!
Im sure ive sed it before but this car is gonna be a beaut when its done!
My Build Thread
Although I've just looked at pics of my shell and they definately were originally fitted through the hole.
Just a thought……
It's a bit lame of the panel maker though. About the only one criteria (other than holding a spare wheel) is that the tub fits through a hole - you wouldn't have thought it would be that difficult for them
Keep up the amazing work
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
Hairyarse said
Good job in making it fit
Cheers, Andy. I'm just wondering if they have a Q.C dept at werk34
ant5 said
Amazing thread, great attention to detail.
Thanks Ant, just on the final push now
Cero said
they're just not well designed.
you're right there bud!!
On a sde note, can anyone confirm for me one thing?
My car is a gti originally so the engine mount is already in the big block position. I don't need to remove any engine mounts and relocate them for the 20V T conversion do I?
Thanks in advance.
Matt
smudger said
Another amazing update dude. Massive respect for all of this hard work and effort.
Cheers dude, much appreciated
pazwaa said
I've been away for 12 days with virtually no Internet access, got home and caught up with you're updates, seems you've been very busy andy!! Top notch work as ever, like the use of the ratchet strap. Clearly no quality control were the wheel well came from. So close to paint, can't wait for it to begin.
Matt
Can't wait either mate, won't be long though
Secretary
As you've all said the spate wheel is dropped into the floor and spot welded from the top. Its also welded to the cross member under the floor.
I ended up welding mine from underneath as removing the old one was one of the first jobs I did and at the time I didn't know about spot weld drills so drilled right through cf_emoticons__BangHead: It's all done now anyway so here's a small update from the last couple of days.Macca said
Nice work mate As you've all said the spate wheel is dropped into the floor and spot welded from the top. Its also welded to the cross member under the floor.
I took the wheel well back out and made a couple more adjustments. I the bared the metal on the lip and applied weld thru primer as per
I then refitted it, welded it in and then bare metalled it before applying zinc primer
shiny shiny
tonight after work I went down and zinc'd it
Tomorrows job is to seam seal, then epoxy mastic the rear arches,wheel well and the rest of the floor. Once that is all done she's going back on her wheels so I can do the rear panel. I'm off work for the next ten days so you can guess where I will be
I too am off for the next ten days, though I won't get to spend much of that time in the Garage unfortunately!
I will deffinitely make some progress, but I fear nowhere near as much as you might!
My Build Thread
Melteddrummer said
Nice one! Fantastic work!
That's so worth the extra effort to get it right
The underneath of your car is looking spot on.
