'83 Gti 16v turbo
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/th_fff9e3ea.jpg)
![Brad. in the usergroup ‘Old timer’ Brad. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Been at it today… Repaired the striped flange I had complete with new bearing
![](https://vwgolfmk1.org.uk/uploads/pbextract/1283365/B053FA61-9295-4657-833C-E1777A266380-9160-00000B6BCE29C0DC.jpg)
Cut my gear shifter and my old one to weld together so I could use my ally golf ball
![](https://vwgolfmk1.org.uk/uploads/pbextract/1283365/5ABAE6F5-10CD-41DB-946E-3551329ECDBF-9160-00000B6BB8092544.jpg)
Chucked a slim line fan ont top fill rad
![](https://vwgolfmk1.org.uk/uploads/pbextract/1283365/32CF2AD0-1E81-46F8-A361-0A41F7F9E83B-9160-00000B6BA745BEBC.jpg)
NEW WHEELS!!!
![](https://vwgolfmk1.org.uk/uploads/pbextract/1283365/D2ECDA5D-10FD-4036-8132-974FBB8DE069-9160-00000B6B96E13860.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1283365/4639B350-EFD4-4980-8C3B-747B7BA0B359-9160-00000B6B9130C77E.jpg)
Needs to come down a bit but my coils are seized
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Nice rims btw
Brad. said
Thanks lad! No chance if her moving in yet… Doesn't know about the series 1 either![]()
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/95image.jpg)
![Dubbuds in the usergroup ‘Old timer’ Dubbuds in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Piers in the usergroup ‘Local’ Piers in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Wd40 ain't budging coils either we have stronger penetrant at work and that won't
Got some tidying up bits done yesterday and swapped wiper motor for a mk2 item
Also tidying yet more wiring up so it looks neat in there, will be attempting some lathe work on say to make a spacer for my trigger wheel and hopefully, a strong one at that, get it fired up!
![chipster2407 in the usergroup ‘Old timer’ chipster2407 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Glad you approve though
![:$](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blush.png)
Megajolt is mappable ignition, so I can map my advance and control it more than the Kr setup
Simple enough once its read and understood
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
Brad. said
Cheers fella, its the reason I can help you out with the box and what notsame heartaches over here!
Glad you approve though![]()
Megajolt is mappable ignition, so I can map my advance and control it more than the Kr setup![]()
Simple enough once its read and understood![]()
Ah i get it, one thing i wud do tho in my opinion is go back.to.the deeper splitter, i never usually like the deeper one but on.urs it just looked sweet as mate
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Brad. said
Cheers lads!
Wd40 ain't budging coils either we have stronger penetrant at work and that won't![]()
What's the stronger stuff you've tried? Is it ACF50? That's supposed to be the danglies
Made a spacer up for my crank wheel, needs spacing out due to the rubber dampener on the abf pulley can cause false signals
![](https://vwgolfmk1.org.uk/uploads/pbextract/1285739/75822E68-3E81-4215-9E37-5F7F5EE77A57-15781-0000144989B9EE94.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1285739/F3C58F4E-7986-4C8D-BB12-B199E135268A-15781-0000144991CDF5B3.jpg)
So, exhaust on tomorrow, finish coolant system (pipe rad up) and then, fingers crossed, start up day! Fingers crossed
![golf_coupe in the usergroup ‘Old timer’ golf_coupe in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
golf_coupe said
Looks good on the cookie cutters
Cheers fella
smudger1980 said
Good luck dude![]()
Confident in my wiring
