which 1.8t engine
(In Topic #134094)
![mana in the usergroup ‘Regular’ mana in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
which 1.8t engine
hi there
i am new to the forum and own a mk 1 1.5gx golf
i am looking to do the 1.8 20vt conversion however as there are so many variations of the 20vt engine i am confused as to which 1 will be best ot work with
i have read that the AGU enging will work but at the same time i have read that an AEB enging will also work
wondering if any one can clear this up for me??
thanks
thanks
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I think the AGU is popular because it has a big port head which i believe isnt really of any value untill you need to make big power, it also has a throttle body which accepts a cable unlike some others which are drive by wire (?) easily swapped for an agu one, i think its best to get a transverse engine though as the longitudinal ones (including aeb) need sump/manifolds maybe more changing.i am using an AUM.
![Jeevesraf in the usergroup ‘Local’ Jeevesraf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
AGU's are very common and can be picked up cheaply if you hit the right breakers yard. As the last poster said, its best to go for the transverse mounted engines as these need the least modification.
There are a couple of build threads and how to threads on here and Club GTI that are a good read if your serious about the conversion.
06 Audi A3 (Wifes daily)
thanks for the reply guys
i had been told about the conversion using an aeb engine as i was told it goes straight in
but on the other hand i had been told alot that agu is the way to go as a number of people have used this
