MK3 POLO GT ENGINE IN MK1 GOLF...WHAT GEAR BOX TO USE?
(In Topic #136830)
Hello people
I'm looking into putting a polo gt mk3 engine into mk1 golf, what do you think would be the best gear box for me to put in and replace the 4 speed box thats in now. On a budget so looking for it to be cost effective.
Thanks for taking time to read this, hope to hear your advise soon?
Tommo89
8P is a good code to go for, if the polo GT box isnt available
regards
Ive Drove Many Cars, But NONE Like A MK1
to get rev counter just change the dash and job done, though if you're usign 1.0-1.3 gearbox you need to swap your old speedo into the new dash cluster
So far have the polo gt engine paired with the standard golf c 1.1 gear box, 4 speed.
Will i need a different clutch etc…
then you need a 5 speed mk2/3 polo box mount, which you cut in half and weld to the mk1 box mount. you'll see what i mean!
thats about it really, need to modify the stick housing under the car so it will let you select 5th, and you might need the 5 speed box shift rod if the old 4 speed one wont fit your box
AHZ is a 1.0 polo box
regards
