mk2 pb engine for mk1
(In Topic #147918)
![jeev in the usergroup ‘Regular’ jeev in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
hi, iv seen a 1.8 8v pb engine for sale, just wondering what i would need to do to fit the engine and what would need to be done to the loom?
what age was the mk2? do you know where the hazard switch was?
what mk1 is it you have
its from a 1990 g-plate and hazard lights on top of stalks. Also it's going into a 81 1.6 gti, thanks
ok it wont plug in then, you'll have to splice it. also since its an 81 i strongly recommend you bin the fusebox as its just not good enough, it cant even handle k-jet properly as it melts the fuel pump pin!
if you had the complete mk2 loom you could convert it to fit your car, otherwise you could get a complete post-82 mk1 or cabrio loom and replace everything.
an alternative is get a 1.8 8v k-jet dizzy and injector inserts, front metal coolant flange, then convert the pb engine to kjet, drop it in and run on the existing managment
