Mk2 Front Subframe
(In Topic #149323)
![Climbatize in the usergroup ‘Local’ Climbatize in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mk2 Front Subframe
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
MK1 Golf 4x4 Build
im not sure if the column end is same on mk2/3 as mk1, if it is the mk3 uj will probably help as its already split so you can adjust length. if not it will probably still help alot as you can cut mk1 uj and adapt it so it bolts to bottom half of mk3 maybe?
