mk1 golf small 1300cc engine to polo 1.3gt on bike carbs :D
letmeknow what you think?
simon
p.s. it sounds absolutly AWSOME! WAAAAARRRRPPPPPPPPPPPPPPPPPP :twisted:
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Login to a private Photobucket.com albumI wanna do it too! Could you give us the rundown of all the parts you needed for the conversion? Is it just Carbs, fuel press. reg, fuel pump and manifold? And the new block obviously!
Nice work simon and well done! 8)
manifold you can get made up for about 160ish quid, but i lookd at the manifold and it dont look that hard to make yourself actually. i used a polo 1.3gt engine running on electronic ignition that is used of the mk2 late carbd model useing the dizzy with hall sender wire loom from the hall sender to the coil and to the module. cant really tell you alot about the engine as i bought it of some one of here. im using a solid state fuel pump (facet) can be pciked up for about 15ish quid of ebay, and a filter king fuel pressure regulator with a return pipe to the tank for the excess fule to go this was about 68quid but you can pick them up of ebay for about 30ish but i wanted mine brand new and i needed it urgently.
using the same throttle and choke cables polo gt gearbox, didnt have to swop my driveshafts or engine mounts as it was a straight swop. just got to fiddle about with some water temp senders as the polo ones have to wires coming of the temp senders and mine had wire to the gauge, any help on this would be appreciated
any more info wantedlet me know and ill try my best to help if not ill try and find out for you
simon
Login to a private Photobucket.com albumI bet it sounds fapping gorgeous! :mrgreen:
You have given me some inspiration to get my ar*e in gear and sort out some tubing for my manifold!
hopefully should be up and running on sat, then gona go and get the ar*e end out at the nearest roundabout!
will try and get some pics and video up on sat.
simon
p.s so i connect my wire to one of the terminals on the sender and the other terminal i connect to earth?? dont matter which one goes where?
chears!
Login to a private Photobucket.com albumLogin to a private Photobucket.com album
Login to a private Photobucket.com albumReally smooth and free reving motor that is! Could do with an Ashley 4 branch manifold and a Piper cam but it's a real little screamer!
Have fun with it!!
yea manifolds angled to meet the carbs, carbs sit on it with silicone hoses, will try and get a better pic this weekend for you.
simon
Login to a private Photobucket.com albumyea like u said its a very quite engine!
hopefully fingers crossd will be up and running on sat
Login to a private Photobucket.com albumWell it doesn't go like a normal 1.3! - lol - it feels far fitter than that!sim0n_parker said
ccol, by the sounds of it then u know your way around it then, ill bear that in mind when i have some probs if you dont mind. so what does it go like for a 1.3??
It is really responsive, especially inthe mid range. Real little screamer.
I drove a standard small block VW earlier this week and this is going to sound awful but - I'd forgot how slow they were (I've been driving moded Mk1 Golfs for too long - lol)
Login to a private Photobucket.com albumsimon
Login to a private Photobucket.com albumNot sure how long I'll be able to help you as my posting style is objectionable.
As far as I know it's a standard 3F motor. It had a leaking gasket when Matt bought it if I remember correctly which he sorted out before fitting the engine to the car.
It would be worth considering getting the head worked and a reproiled/performance cam fitted.
Me and Guy off PVW are on building a very similar high output unit from a 1.3 for a late Mk2 Golf at the moment. Reprofiled cams are apparently cheaper (?90 to ?120) than Piper items but either are good.
There are two head designs. One has the squish band/combustion chamber in the piston crowns, the other in the head. If you've got them in your head you can skim it down to get the compression up a bit (although it is less important on a 3F as you are already running 10.5:1 instead of 9:1.
With head work, cam and a free flow exhaust, along with those carbs, you should be able to see a healthy 120 to 130 bhp ATF.
Best of luck!
Looking forward to hearing this. Make sure you make a video/recording and we'll upload the soundtrack!
Cheers,
Drew.
