less is more, mk1 upgrades
(In Topic #80364)
Re: less is more, mk1 upgrades
post said
if you are undertaking an engine swop or just want to empty your engine bay, don,t spend money on shiny fan cowlings etc, only to us a 20 year old fan ! bin both. Patec make slim line fans that do not need a cowling, direct wire in ,are modern and way more reliable.They can be mounted in front of the fan aswell.Then get a new rad. from G&S etc. for an early Sirroco, they are top fill and do not need a header, so you can ditch the header and pipes, once agin its a new rad so more effective than one that is second hand or 20 years old,plus it looks mint. Fan about ?85, rad about ?45 or so. Now someone is thinking that VW developed aheader for a reason etc…, well if you got your head in your engine bay most of the time like most MK1 owners you will certainly check water levels ! Sinny cowlings are about ?50 and most folk buy a new header and they cost over ?25, and you still have an old fan. Also while your at it get a new low temp. sender from G&S which will bring your silent new fan on earlier.
:roll:
If you're going to make your cooling less adequate then I'd suggest a more modern fan too :wink:
My Build Thread
I thought that they only made suspension components?
less is more
G60
