is it possible put abs brake and all wheel drive the mk1 ?
(In Topic #140149)
![csari in the usergroup ‘Regular’ csari in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
i wanna learn that is it possible that put abs brake system and make all wheel drive mk1 1.8 gti ? if this possible, which car's which parts needed ? Thanks for helping.
4WD has been done a few times but the work is extensive and even then, the related cars (like Mk2 Golf Synchro) you might take the parts from, are getting old, are quite rare, and the 4WD system isn't that good in them anyway, being part time systems that detect slip then progressively engage RWD. If you wanted a better, more modern system, then you'll need to do a lot of electronics and/or use some kind of standalone controller. And it adds weight, which has a negative effect on the handling and performance which isn't gained back unless its really high horsepower or non-tarmac road use of 4WD.
Thanks for your reply Paul. I understood what you mean. I just though a car looking old, but system is modern ( engine or brake or etc) I think better is use original mk1. thanks again.paul_c said
The problem with ABS is that while you could in theory transfer the components from one car to another, its way it works relates to the weight, and the weight distribution, of a car quite closely. So it would work of sorts, but not ideally. Last thing you want is ABS that makes braking worse, not better.
![Avatar](https://i9.photobucket.com/albums/a55/laughingboy_1978/a3e1cf5a-b37d-466e-b185-aad4fb4a558e.jpg)
![Laughingboy in the usergroup ‘Local’ Laughingboy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
By adding aftermarket traction control from the likes of racelogic you can add the option for launch control and ABS, guy I used to know stuck a T16 engine into a peugeot 305 works van and used this system to keep it in check!
thanks for information friend. i'll try do it.Laughingboy said
ABS is very possible.
![Willowraf in the usergroup ‘Local’ Willowraf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
polo 9n abs pump unit.
mk2 g60 front hubs + isomeric top mounts.
mk3 golf anversery rear disc conversion.
all abs wiring for sensors and pump connector.
Then mash it all together, works a treat on mine also with the added 1.8t tractions control works as well..
![](https://i1201.photobucket.com/albums/bb358/willowraf1/PROJECTSTORM.gif)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Willowraf said
Yes! using all VAG items as well.. Parts Required:
Interesting!!!
Regards Volkswarren
Steering rack track contol arm extender…. An time…hehe
![kyky in the usergroup ‘Newbie’ kyky in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Everything is possible!
About the 4WD part - here are some very useful links to see what is needed:
http://www.qpeng.com/gallery/?g2_itemId=202
http://www.clubgti.com/forum/showthread.php?t=228147
http://www.clubgti.com/forum/showthread.php?t=204200
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=417265
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=33996
http://forums.vwvortex.com/showthread.php?4805804-My-1.8T-Mk1-project
This are some of the 4WD(there are even 4WD&ABS) conversions - you can make it your way. Some have shortened the rear axle others haven't. You should consider this and also the propshaft length
Both ABS and 4WD combined is not a problem - you can take the rear parts from a Passat B3 G60 syncro or B4 syncro - most of them have rear discs and have ABS. The front is the same 2WD/4WD.
I hope that clears the questions.
Best regards,
kyky
![gonzalogamir in the usergroup ‘Regular’ gonzalogamir in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
https://www.bolt-action.nl/product/vw-mk1-abs-hubs-and-sensor-adapters/
