heaters again???
(In Topic #117954)
![Chriso in the usergroup ‘Regular’ Chriso in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
heaters again???
Now its getting frosty i need heat!!
I tried one of those ceramic heaters that plug into the cigarette lighter but it is POOP!!!
I have found this on ebay. What do you guys think??
http://cgi.ebay.co.uk/Lightweight-Heater-Unit-Single-outlet-0-68kg-Kit-car_W0QQitemZ190336804657QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2c50f52731
How hard would it be to fit? will i need to plumb itin to the cooling system?
If so where? What other components will i need?
I know i will need the ducting and connections but what about for tapping into the cooling system.
Thanks in advance for your help.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/rsz_null_zps87eca6a6.jpg)
![paul_h in the usergroup ‘Old timer’ paul_h in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://i23.photobucket.com/albums/b369/Paul_H/stuff%20forsale/P140209_0905.jpg)
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
Ok so this is an electrical blower? How powerrful?
How much do they cost? I have looked on ebay but no joy. :dontknow:
I am looking for some heat aswell as a demister so will i need some ducting and vents?
I have a S1 dash and there is not a lot of room.
Is it defo an e30 and not an e36?????
Thanks again for your help, i will not ignore it again
them blowers are heated aswell
![jonwelsh in the usergroup ‘Local’ jonwelsh in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
just been looking at 12volt heaters on ebay, would 2 of these under the dash be sufficient if plumbed into the original pipes?? so that heat can be directed into cabin or at screen?? this would also do away with water pipes going into bulkhead.
http://cgi.ebay.co.uk/CAR-HEATER-HEATING-FAN-PLUGS-INTO-DASHBOARD-12v-12-VOLT_W0QQitemZ360121166603QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item53d8e4eb0b
I am going to put in a heated front screen to solve the demister problem and i have purchased the bmw rear demister to use as a heater. Its an electric heater/blower. Cost ?20…..
Went to start the install of the heater when i found the car would`nt start so have been focused on getting it going again, i think it is the starter.
I will update when i get it working but prob wont be until after xmas as i am away on holiday for a while.
![rnp600y in the usergroup ‘Local’ rnp600y in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
<a><img></a>
to make a demister work it needs to have a freah air supply??
could i use a bmw heater and run a fresh air supply across the dash from inside a wing, with a filter on the end in the wing to stop crap being sucked in???
this would do away with the intake in the scuttle. no pipes would run into bulkhead and my heater would work!!!
if this is a possibility i would be very happy!!!
It works on the same principle as a hairdryer…….. you will just need to make up some ducting to channel the airflow.
I think you are trying to complicate things.
![Dibdub1 in the usergroup ‘Local’ Dibdub1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
wuld just an electric heater work??
![balders_uk in the usergroup ‘Newbie’ balders_uk in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
http://www.heatedwindscreen.com/
for heated screens, does anyone have any experience of them on the Golf, are they worth the outlay, do they come with any suggestion for rigging up the power supply/control etc, I had heated screen and seats on an M5 but out here in Dubai I didn't use them very often!!
![MK1QUINNY in the usergroup ‘Local’ MK1QUINNY in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
where can I get one of these from and does anyone know of fitting instructions I could print off and where to place it any pipes needed etc
please help me guys I'm getting all excited now about this
I HATE CAR & SCENE SNOBS
