From 1.6 to 2.0 8v what I need
![LaJe in the usergroup ‘Local’ LaJe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/23377_10200579018022023_2056382323_n.jpg)
Tadan!
![:$](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blush.png)
I have to use my fuses box or ady fuses box? I'm so confused
![:ninja:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/ph34r.png)
the good news is that since your mk3 is LHD, the loom lengths will be about right for your mk1, over here its more of a hassle as on RHD mk1 the fusebox is still on the left, on mk2/3 the fusebox is on the right so not long enough!
if you go for the mk3 wiring most of it is just a case of get the wire colours and match them, but i would get yourself a 90spec mk2 golf dash clocks loom if possible as its coloured (mk3 is all white wires!!)
this will help:
http://www.clubgti.com/showthread.php?249714
Look the topic right now!
Where i can find it? I use the mk3 pin? How can I do it?
I use this:
Central Electric 1 and this Central Electric 2
for the light I add my wiring and I have to know where some wires go
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
CE1
c01
c02
c03
Then I start the internal and OMG it's a delirious
I take off the A in CE1 but some wires go in J/G/H. is it right?
In specific:
A02, A04, A05, A06, A07, A08…
But there are the red! Why not the blue? Help me please
Different color wire??
all the A in CE1 are different in CE2… I dunno why…
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
So:
https://docs.google.com/spreadsheet/ccc?key=0AoOKZ6EBLTsqdDRqWGdwdXJ3Vkh3VVRkVlJkVUhiaEE&usp=sharing
That what I did. I'm not sure about all, I've some dubt about CE1 a4, b7, b12, a3, b14, b19 and I really need someone that can take a look at this file and say me if it's works or not.
Every help it's really appreciate.
https://docs.google.com/file/d/0B_V9-6xfgGlITDhSVTRYSk45bGc/edit
Last edit: by rubjonny
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
rubjonny said
I hope you appreciate all the effort that went into this
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
I love you. I can't say nothing else about this work. Really… Maybe I cry now.
![:'(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cry.png)
if anythign doesnt match up tell me the pin numbers and I will advise
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
Ok, this weekend i try all
A/9 R/9 Headlight switch pin 56
A/9 J/2 Flasher switch pin 56
Ok I've one wirint but two pin. So? What do i do?
you have 2 options, either wire it as per ce2, or ignore fusebox entirely and wire them together like CE1. the advantage of doign it ce1 way is less complexity, the advantage of ce2 way is it means loom is more modular. i.e. on ce2 you can unplug headlight switch loom on its own, on ce1 you have to take the stalk loom out with it
the choice as they say, is yours
My 1.6 is different the wiring, so I haven't the wiring for the two pump.
So? What I do now? I buy some new wiring or I can add a cables in my wiring?
Thanks.
then its a case of make the rest of the wiring loom fit your lights, all the wires you need are there in fact you'll have a few extras for the rear wash/wipe which can be cut out. the cabrio rear lights take spades so its just a case of cut mk3 plugs off and crimp spades on, matching the wire colours to your rear light units
