From 1.6 to 2.0 8v what I need
![LaJe in the usergroup ‘Local’ LaJe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I'm so fu**ing happy.
![:wub:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wub.png)
What cable is? The green and? I can't rembember, a friend says me what is but i forgot LOL.
mk1 clocks
1. open mk3 coil, run wire from -ve terminal inside to fusebox pin g1/12 (cut the old wire)
2. bin the mk3 coil, chop the plug off. crimp a spade to the black wire, bin the brown wire. pull the green/red wire back towards the ecu.
next find the TCI plug on your old wiring loom, its the 7 pin thing in the scuttle. fit it to the mk3 engine bay the same way it was before, but splice the green/red mk3 wire to the tci unit pin 7. bin the other 2 wires from the tci plug that used to go to the distributor. run a wire from the coil -ve to g1/12
fit mk1 tci and late mk1 or mk2 coil (check the plug lead connection compared to the mk3 coil) job done
I prefer option 2, as the mk3 coils are unreliable. but you could leave it for now and convert it later
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
First or second gear, undertorque (sorry Google translate suggest me this i hope it's right) and try to start or get more accelerator, the car litteraly jump and tug!! It's like a crazy horse!!
How I check to understand what the hell is wrong?
Sometimes i can listen a noise like 'tictictictic' from one or more cables! Maybe that's the problem!
![:$](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blush.png)
Other question:
In this photo i circle a pipe that i close, BUT i look at etka and it goes to a CHARCOAL CONTAINER.
That's absoluly essential?
Thank u!!
