brakes...
(In Topic #77188)
brakes...
I am looking at fitting this to my mk1 driver, i was wondering if there are any problems people have come across?
At the moment i have…
vented 256mm drilled discs
pads for above
calipers
carriers
solid 239mm rear discs
bearings
calipers
carriers
stub axles
backing plates
i know i will need new handbrake cables (are the 16v scirocco ones suitable?) and a bigger master cylinder (any recommendations on size/vehicle?)
Chris
hope this helps
if you need anything else, i will try and help you as i am nearly finishing the conversion my self for a friend, and can tell you what troubles i came across.
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
which flexihoses did you use just standard mk1 ones?? I think i will be replacing them with braided ones anyway
Is the mk2 16v master cylinder the best to get??
I will be converting the front first which should make life easyier as i will make sure all that works properly first, but what model do i get the proportioning valve from?? (is this the same as the bias valve?)
good luck with finishing yours off
Chris
simon
<a href="
