Best brake upgrade possible???!!!
(In Topic #123603)
![haywire in the usergroup ‘Regular’ haywire in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I was considering MK3 GTI callipers and necessary adaptors etc with braided hoses and some nice, fast road pads. As I don't think i'll ever bother with rear disc conversion I want the sharpest most effective set up on front.
Suggestion pleeeeease.
In Dorset, a "technical" usually involves bailer twine and a lump hammer…….
![wooders in the usergroup ‘Local hero’ wooders in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
or leave them as standard and live life on the edge a little
![g60bron in the usergroup ‘Local’ g60bron in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Bearing that in mind you'll want 16v master cylinder and mk2 servo with braided hoses. bout as good as you'll get
1992 Clipper Cabby - Love VW!
yes you can. rally design do a 247mm set up, which will fit under 13" rimsg60bron said
Can't go any bigger than the std 239's if you want 13's
![mrscratch in the usergroup ‘Regular’ mrscratch in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![ManicGTI in the usergroup ‘Old timer’ ManicGTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
No idea how effective they are…I would have thought more people would do it was worth it. Bear in mind it would need a master cylinder direct off the pedal (ie proper pedal box). Plus it needs vac feed from intake still…
this thread is damn useful:
http://www.nsra.org.uk/forum/topic.asp?TOPIC_ID=13193
