A design fault for all Mk1's?
(In Topic #80601)
![TimHale in the usergroup ‘Local’ TimHale in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
After being lectured by someone who been fixing VW's for longer than most of the forum have been on this planet, I get the impression that the MK1 exhaust manifold was always a problem. Moreover the later models with the round coupling were even worse. The Mk2's solved the problem by fitting a flexible coupling from the manifi=old to the downpipe.
The problem seems to be an excessive amount of movement of the motor which fratures any exhaust coupling or worse, the manifold.
Is the only answer to tighten the gearbox mount as much as possible and to fit a sliding joint in the exhaust system?
Answers and advice would be helpful
Tim
![Avatar](https://i78.photobucket.com/albums/j95/citigolf_2006/Avatar0.gif)
![Bert in the usergroup ‘Local hero’ Bert in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Bert in the usergroup ‘Paid Member’ Bert in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
Bert
![Avatar]([IMG]http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg[/IMG])
![sim0n_parker in the usergroup ‘Old timer’ sim0n_parker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i always have the last laugh ![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AVATAR.jpg)
![AL_Mk1 in the usergroup ‘Local hero’ AL_Mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Seriously though - I have never heard that before… :?
My Build Thread
![Woolley in the usergroup ‘Regular’ Woolley in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
I remember this question coming up before and 'crasher' who used to post on here and i think is the brain at C and R ? Recomended that to prevent this problem only use an approved standard exhaust or some thing like a Jetex and replace those worn mounts to give the engine some flexibility
Cheers………….
It seems like a good plan.
But will it work?
Guest user
![stuGti16 in the usergroup ‘Local’ stuGti16 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
what do you think i swapped to another manifold new gaskets and is doing the same still
Stu
www.msportcam.co.uk
![Mr_GTI in the usergroup ‘Old timer’ Mr_GTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
This is going to be fitted plus new mounts-later in the year a big valve head will complete the job.
That should make it burble nicely.
![ManicGTI in the usergroup ‘Old timer’ ManicGTI in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
