91 clipper I need advice!!
(In Topic #155165)
Hi all I'm looking for a bit more performance from my clipper and my knowledge is 0 heard and it changing carbs which sounds like what I want to do what will this give me?? Also what is required to do it & cost!!! any advice will be a great help thank you.
Alex
Alex
What carb is on it. If pierburg swap it for webber thats all i know. Im converting mine from auto to manual and putting a dx engine in
webbers are about £300 iirc
The car is 100% original!!! Thanks
weber on its own wont do much if the original 2e2 is fully functional, but if you start flowing the head and campaign it up etc then weber is beneficial as its more easily tuned. ask a rolling road guy about jetting a 2e2 and i think they will be unimpressed
Cheers think im going to have to do more looking into it may be a job for the winter!
I asked exactly the same question when i had my clipper and to be quite honest by the time you have started buying new bits and playing with the engine, you are better off consdiering selling and then starting with a GTI cabby from the beginning and tunnning that.
My pierberg carb went around 90K ish so i replaced it with webber carb on manual choke and the car did seem more responsive, but not a great difference in power change at the wheels i am sure.
You have such a low mileage original example i would be tempted to maybe put a mohair roof on it on it and stay stock with everything else, but then i am getting more and more into liking stock these days :-)
1.8T CABBY
1.8T CABBY
Thanks for the advice Rich!!!
Someone else pretty much said the same thing to me today. The reason I got the car was coz it was standard and he said just change things when they break and just keep her as she is!
I think your right il change the hood at some point but its not urgent. Also I want to get some 15" alloys so she sits better and fills the arches out ( any ideas what ones??) other than that she's staying the same!!!
Alex
Alex
depends on the look you are going for , and budget!
i went exactly along the same route, some 15's to fill the arches out
i went with Lenso BSX which are a split rim copy, you can see them in my clipper thread. Mine were fine but the clipper never saw the rain, i have heard reports from people using them daily that in the bad wether they can start to suffer from laquer peal and corrosion around the tfake bolt
Dare RS rims are nice, you can find them online, and they do wider rear so you can stager wider on rear and thiner on fronts
also you could consider usual suspects like ATS cups, ronal turbos etc
There is a wheel tha looks like the snoflake wheels tha i think look really good, they arnt cheap though , they are called Fifteen52 snow flakes, you can see on one of our members golf in this thread:
OEM Wheel swap pics - Page 10 - General Gassing - PistonHeads UK
http://forums.vwvortex.com/showthread.php?5672883-FS-FIFTEEN52-Snowflakes
with wheels its all down to personal preference though :-)
Rich
Rich
1.8T CABBY
1.8T CABBY
Cheers Rich I thought I replied but I didn't! Think il be getting some in the winter time as the missus has informed me that a holiday is more important than new wheels I guess she's right haha!!!
Alex
Alex
