5 speed in a mk1
(In Topic #147666)
![futten in the usergroup ‘Regular’ futten in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
5 speed in a mk1
i was woundering if anyone knows if is ts possible to ge a 5 speed transmission in my mk1 golf i feel its little high on rpms doing 50-60 mph
1980 golf 1 gls 1.6 4 door
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Big block or small? big block is easy enough.
its a 1588 so big block i guess
whats the judgement? is there an easy way of installing a 5 speed and what do i have to do? and what car can i get a trans from?
Well its a simple bolt in job but i did it over 20 years ago so memory is faint, think i used 1600 gti box and linkage, but can offer no more advice.
yes mk1-3 1.5-2.0 all use 020 gearbox that will fit, but you need mk1 5 speed linkage parts and upper gearbox bracket. you have 90mm flanges on your box so bear that in mind, a lot of the 1.8-2.0 boxes have 100mm flanges which means either get later cab/rocco 100mm shafts or fit later 90mm flanges to your box
thank you very much
now i just gotta start searchin i guess this is gonna be "fun"
