16v engine swap
(In Topic #123998)
16v engine swap
volkswagens dont leak they mark their teritory
The mounts on the MK2 engine need to come off so you can fit the mk1 mounts to it.
You need the tank pump and lines from a gti, you will also need a 16v manifold from ashley or dub power for around £250 to £300. this is the most expensive bit.
Brakes could do with an upgrade but this can all be got off an MK2 16v.
Wiring loom is needed from 16v too with ecu. needs splicing to original loom.
If you do it yourself it can be easily done on a budget.
Plently of info about.
1992 Clipper Cabby - Love VW!
