magic calipers
(In Topic #102770)
![wooders in the usergroup ‘Local hero’ wooders in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
magic calipers
look. 4 pot volvo calipers. won't fit a mk1
and hey presto, now they will
![](https://vwgolfmk1.org.uk/uploads/pbextract/861435/carbits048.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/861435/carbits047.jpg)
![Avatar](https://i222.photobucket.com/albums/dd103/iPod_Fixer/000177.png)
![X in the usergroup ‘Local hero’ X in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
:scratch: :scratch: :scratch:
am i missing something, all that seems to be different is the ridiculous blur on the bottom half of the shot… or is this another 'woodersism'?
1983 Golf 1.3 Driver:
![](https://i222.photobucket.com/albums/dd103/iPod_Fixer/182000_zpsdfa6a837.png)
look closer
![Avatar](https://i245.photobucket.com/albums/gg80/novocaine10/n731220548_174194_274-1.jpg)
![novocaine in the usergroup ‘Local hero’ novocaine in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
youve fitted magic wooders pins. :wink:
rover 216 gti discs fit lovely with these
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![Lawsy in the usergroup ‘Local hero’ Lawsy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
all i can tell is that wooders you need a better camera or a steadier hand when taking pics :mrgreen: :mrgreen: :mrgreen:
i hadn't dah a drink then. i'm a litre and half through of lethalmilf and me mits are as steady as a rock now.
![Avatar](https://i116.photobucket.com/albums/o17/the_parrs/Honeymoon/PICT0071.jpg)
![ant5 in the usergroup ‘Paid Member’ ant5 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ant5 in the usergroup ‘Regional Hosts’ ant5 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![ant5 in the usergroup ‘Local hero’ ant5 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
He has put bolts in the Holes….. Or he is taking photo`s with one hand
ops:
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
![welsh-mk1 in the usergroup ‘Local hero’ welsh-mk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
ant5 said
He has put bolts in the Holes….. Or he is taking photo`s with one handops:
Magic bolts.
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![djheap22 in the usergroup ‘Old timer’ djheap22 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
fitted longer bolt with shims to get the caliper in the right position when bolted to the carrier. :dontknow:
1988 1.8 carb Golf Clipper
yep. got special shaped spacers and longer bolts to fit the to mk1 carriers using rover 216 gti discs. need to t piece the brake lines and on they can go.djheap22 said
![thoyland in the usergroup ‘Local’ thoyland in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Top conversion, wasn't this featured in cars and car conversions magazine ages ago? I think they also used austin princess 4 pots as well?? I remember the 216 GTI discs as the common denominator.
![mcscrew in the usergroup ‘Local hero’ mcscrew in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
What model Volvo do they come from, and what diameter are the Rover discs?
Also, do those calipers bolt to standard GTI carriers?
Rich
Rich
I don't suppose anyone knows the total surface area of the twin cylinders in the Volvo calipers as a comparison of the stock VW one. This info would be needed to calculate the resulting diameter of master cylinder needed, and/or the change in pedal stroke due to the changes.
![chrismk1jetta in the usergroup ‘Local’ chrismk1jetta in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
you lost me there paul!!
they calculated this in the mag (c&cc) when they did the conversion and it was considered fine. i can't find the article at the moment but if i do, i'll post it up.paul_c said
![racer in the usergroup ‘Local’ racer in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
calibra turbo calipers bolt straight on with sleeved bolts give you 280mm
![frackagx60 in the usergroup ‘Regular’ frackagx60 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
hi im a new member just read this thread the other day, joined, found some of the same calipers on ebay, befor thay arrive, could you be sokind as to advise me on sizes of the spacers.anything would be appreciated.
![collo16v in the usergroup ‘Old timer’ collo16v in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
What model Volvo wooders? :dontknow:
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
anyone? :dontknow:
