Vacuum Advance Unit Help!
(In Topic #224174)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/image00002.jpeg)
![Viggymaster in the usergroup ‘Regular’ Viggymaster in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Vacuum Advance Unit Part number needer
I have a 1983 Golf Mk1 GX 1.5L engine code JB and need to know the vacuum advance unit part number for the car. The distributor is 055905205K and has a vacuum advance unit with only 1 port. All i keep seeing is ones with 2 ports, does this matter and how would i connect it to my weber 36tlp
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/bonfire.png)
![Vic in the usergroup ‘Local’ Vic in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Looks like Crazy quiffs list a complete reconditioned distributor.
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![Steve1973 in the usergroup ‘Local’ Steve1973 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
There is usually a code stamped on the rod that connects to the distributor. You'll have to take it off to have a look.
