Fast idle after WUR rebuild
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: Fast idle after WUR rebuild
Sorry to be uneducated on the post where do you put the vacuum pipe on the wurgregpank said
Thanks. I didn’t follow that, but rather the instructions that came with the rebuild kit from missing-parts in Germany.
The difference between the two is that the latter doesn’t instruct you to remove the round fuel cell but instead shows you how to rebuild without doing so. It does state you have to very carefully ensure the screw adjustment is at exactly the same spot when reassembling it - which I did.
My post a bit further up shows the pressures I had after the rebuild which seem in tolerance. I think?
Sent from my SM-G975F using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0971.jpg)
![gregpank in the usergroup ‘Paid Member’ gregpank in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![gregpank in the usergroup ‘Local’ gregpank in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Regional Host NE
So what does the vacuum actually dogregpank said
I have a later mk2 scirocco one which has a vacuum outlet on the side. You then connect this to the vacuum system up on the throttle body. I think some simpler/earlier versions dont have a vacuum putlet and so arent designed to be connected
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Regional Host NE
So why not disable you vacuum I do not understand why you need it personallygregpank said
Enrichs the fuel mixture at full throttle. Kinda a secondary function to its main warm up job. I think!
![](https://emoji.tapatalk-cdn.com/emoji12.png)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Regional Host NE
Do not understand where you are coming from mategregpank said
“Why climb a mountain? Cos its there”. Same principle![]()
I didnt clock it yesterday but the junior timer connector to it (below and to the left of the cold start injector) was disconnected.
… I had pulled it previously to check continuity…
So ill make sure it has a good connection and try again. If its that then i shall slap my own forehead.
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Regional Host NE
Hope it sorts your problems good luckgregpank said
Missing-parts suggested i check the AAV.
![](https://emoji.tapatalk-cdn.com/emoji106.png)
Regional Host NE
Re: Re: Fast idle after WUR rebuild
Probably off the topic I run 2.0 abf on kjet mk2 also kr in the cabriolet on kjet neither use aav or isv no vacuum to the wur both running finenicci21paul said
So ill make sure it has a good connection and try again. If its that then i shall slap my own forehead.![]()
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
It's an old school mod for tuned engines (cams, gas flowed, etc) at wide open throttle the drop in vacuum lowers the control pressure allowing for more fuel to stop it leaning out.
Obviously I've done it to mine 😁.
Sounds a likely culprit….
![](https://emoji.tapatalk-cdn.com/emoji851.png)
Still needs a good tune so off to the local rolling road guy in the next few weeks… thanks for the advice and lets hope she stays fixed!
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1552036688.jpg)
![Backinblack in the usergroup ‘Old timer’ Backinblack in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://emoji.tapatalk-cdn.com/emoji23.png)
Glad you sorted it.
and then realised it was a left hand thread.
cedar said
We all miss simple fix's, I once changed the complete back axle on a Frogeye because I thought the threads on a hub had gone (I was working outside in the semi dark),
Nooooo! Bet you laughed about that afterwards…
