Middle silencer pipe
(In Topic #239863)
![0337 in the usergroup ‘Paid Member’ 0337 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![0337 in the usergroup ‘Old timer’ 0337 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
https://www.ebay.co.uk/itm/403825347045?fits=Plat_Gen%3AMK+I%7CModel%3AGolf&hash=item5e05ddc9e5:g:XRUAAOSw0lVbIP0X&amdata=enc%3AAQAIAAAA0CKveXJ1mPQNPhrY1yMOfOVqrpV%2BC5NhFEc4xJo9YtW5fJw43x%2FHIcOvN%2B0e7CqW5pqTsxnXLOFsvNa4a3RpIlCEMw6TsJOVWrJTN5eOtHgLXZe0tbDE%2F5gPHc2fCvXIzEsc38jImFS1FYJATRUXz6AG%2B%2FvtpvNeUXFWRUmFHNTqiUSgrtKf0DfUKFxhBF%2F0jdnFwAqi%2FKml2OsMsdtV9xCKP2qj1i0%2BSzF%2BIV4de3IPCkG2Wcjmj2EdV5kEQ9q7bzvlR%2B9KzXQduP8LOWkWq%2Fs%3D%7Ctkp%3ABk9SR9iIxMKgYg
Or here for a UK seller but has a slightly different bracket at the back, I brought one like this but had to cut the brackets at the back off to fit.
https://www.ebay.co.uk/itm/275702583451?fits=Plat_Gen%3AMK+I%7CModel%3AGolf&hash=item403127909b:g:WJwAAOSwiXtj9MwR&amdata=enc%3AAQAIAAAA0A6LUzblSM%2FK5rKFhBcehJ00zvJZDVHnq1tUjOyMxrMypa14fqtLZrUi4RQlQRQtdYbETBtYm3op5fSsnIDWZY%2B6%2BUUQOB%2F6W085crlRGs6ISbVV7yUeK2yx%2Bb4uRQWh8Db%2B6No4efLwV8m2FeKv6dNIXQo28308lRY%2FH3vH2glYUouqmJXeY6Y941mNjL6Hl7GjtRCENS7PMCcB7E%2BLhLtHXV4pmHdMzcsD4RskT6ujk%2BwTFlCE%2Fl1DSnFRram4X9eNV04up9Fp4oek%2BBQiGYw%3D%7Ctkp%3ABk9SR_6-9sKgYg
Found another here.
https://www.ebay.co.uk/itm/150480087941?fits=Plat_Gen%3AMK+I%7CModel%3AGolf&_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3Da20efafc79f241a2a2af8a4f48514cb7%26pid%3D101224%26rk%3D3%26rkt%3D5%26sd%3D403825347045%26itm%3D150480087941%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganicWebV9BertRefreshRanker%26brand%3DVolkswagen&_trksid=p2047675.c101224.m-1
Last edit: by mark1gls
My Mk1 Scirocco has no middle silencer and just a back box as fitted from new.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: Middle silencer pipe
Where are you located mateGreenmk1 said
Hi all, having problems trying to get exhaust system sorted for my 1991, 1.8 GTi cabriolet and was wondering if the middle silencer section is compulsory or could I just get a straight pipe made and put in place. Any info is much appreciated thanks in advance.
Sent from my SM-G975F using Tapatalk
Sent from my AC2003 using Tapatalk
The purpose of this is to stop the hammering of the system to reduce the sound.
It does this by the design that the internal tube is hollow.
It is surrounded by another tube that welded to the interior tube ten sealed on the outside.
When the tube is hot or cold, the hammering effect of the exhaust gas is diminished because the expansion of the Gas Puffs against the interior metal is held in check by positive reinforcement of the heated air of the outer jacket this allows the Gases to flow out more evenly.
It is a pneumatic hammering reducer. The evening out of the pulses of exhaust is more smooth making less noise in the final silencer or Muffler as we call it over here.
Last edit: by Briano1234
Regional Host NE
If you're willing to travel i have middle and back standard if want to ring me 07739608140Greenmk1 said
Bolton, near Manchester
Regional Host NE
