CO too high
(In Topic #239680)
![0337 in the usergroup ‘Paid Member’ 0337 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![0337 in the usergroup ‘Old timer’ 0337 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
See Cabby-info.com Tech, Ignition, DIY timing, Method 2 for Digifants. All you need is a DVOM.
CO too high
Sent from my AC2003 using Tapatalk
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: CO too high
Digital volt ohm metre?Greenmk1 said
GTI also what is a DVOM sorry for being stupid
Sent from my SM-G975F using Tapatalk
Should be the small hole on the metering head and used a Allen key, then I guess the idle speed would also need adjustment
CO too high
CO too high
![](https://uploads.tapatalk-cdn.com/20230712/783055a81d33ed9a70a9235feca4bce1.jpg)
![](https://uploads.tapatalk-cdn.com/20230712/73250f982220ef3b962ab67c6d2ecc3a.jpg)
![](https://uploads.tapatalk-cdn.com/20230712/269a309f9c98281be4d029e3e1597249.jpg)
The MOT testing equipment is the one to to with.and the CO is about right.
After a long run, left the car cool down and then look at the colour of the spark plugs as that will give you a good idea of how it's burning fuel.
White - To lean
Grey - Spot on
Black - To rich.
CO too high
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Looks like you've forked out for a new one and they aren't cheap.
Also sounds like you're keen to learn how to keep your car running properly and all credit to you for doing it… so stick with it, likely be frustrating at times, but it's very doable in the end.
I've the same Gunson as yours, although it's not that snazzy green, just plain old black - tester envy!
Yes the reading will increase if the fan kicks in, bit of a pain, but you need to let it finish its cycle and for things to settle back down again before continuing with the test.
Be the first to admit they're a bit fiddly and if you don't stick to the letter of the setting up / use instructions you're really just wasting your time.
Practise is the key, and a light touch… when you get the hang of it you'll probably be surprised how little the adjustments need to be to get noticble changes.
You'll also get an 'ear' for your particular engine, should eventually be nearly able to set it without having to look at the readings.
I've had mine a few years now and put a couple of cars through their MOT's after setting the CO with the Gunson.
One was a Peugeot 205 on L-Jetronic and the other a MK2 Golf with Digifant, maybe not exactly what you have, but variations on a theme.
These are the 205's / MOT centers readings (theirs is to 3 decimal points against the Gunsons 1).
2021 - 1.3% on the Gunson / the test center 1.320
2022 - 1.5% on the Gunson / the test center 1.530
It's going back in again in a few weeks and I did the CO a short time ago, it hadn't drifted more than a few fractions after a year / hundreds of miles.
https://www.manualslib.com/manual/1482901/Gunson-Gastester-G4125.html?page=5#manual
CO too high
Not sure what's going on but what I would try next is get the mixture back to where it was before, clean the spark plugs with a wire brush so they are nice and clean and if the type you can gap, check the gap is right.
Give it another good run and see what colour they are.
Is the exhaust note and constant sound or "hunting"?
CO too high
![](https://uploads.tapatalk-cdn.com/20230820/06ccb8e313dc538f95b3fb511dc2ad1d.jpg)
![](https://uploads.tapatalk-cdn.com/20230820/77348bdf2e6883aa1f1cbd8c757b18fa.jpg)
