Measurements for rear view mirror
(In Topic #219881)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/bonfire.png)
![Sarah1975 in the usergroup ‘Newbie’ Sarah1975 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Position of rear view mirror on mk 1 rivage convertible
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
Place your Sun visors fully down, then position your mirror between them, You can use a Sharpie to outline the bottom edge. This is so that your visors can go up or down with out hitting the mirror.
Tape the Button to the windscreen on the inside and level it to your mark.
On the outside of the car with the sharpie trace the outline of the button.
To glue it you can use a mirror adhesive kit, 2-part that is glue then activator, or what I have used for years and it lasts longer is Clear silicone RTV. Place a Drop on the Button Press it firmly against the glass and then tape it in position for 24 or 36 hours. Trim the excess glue from the edges after it is dry and replace the mirror.
I used the Activator on my Rabbit Diesel when the mirror fell off, and well it lasted about 3 years. So I figured that I would try Silicone…..It was still going strong after 15 years when i sold it.
Since then that is all I use. If it will hold an Aquarium together I figure it isn't a bad thing to use.
