help with jury rigged ignition wiring.
(In Topic #217021)
Need help trying to work out which wires should be connected by identifying the colours I have and which wire they are. From there I should be able to follow a few diagrams I have of which one goes where on the switch.
Guides say I have 2 black and red that are joined, - think these are the 2 black only wires which are joined?
Single solid red - Ignition Live?
Purple and black - No Idea presently connected to solid red..
Yellow and black - wired to the 2 black wires..
brown and white - also wired to 2 black..
brown and red - not connected to any thing
red and black - wired on its own
any help would be appreciated…
Last edit: by TheBowry
Central Electric 1
I presume you've seen these?
Brown and Red should be 'key in power' comes from a little spade
Red is the ignition switch power. Should come direct from a spade on the back of the fuse box. Try a continuity test to trace it back to the fuse box.
Violet and Black is either the fuel gauge sender or the ECU power or carb power for the auto choke. (which might explain why it kept running as it shouldn't have a live feed all the time I wouldn't imagine or it'll not shut off)
Yellow and black is the ignition switch run power (should also link to headlights)
Red and black is the starter power switch.
Can't find a brown and white. Browns are usually earths. Sure it's just not staining on the sheath maybe?
I think it might be a case of stripping down the column and then removing the 'new' wires and following the guides to get back to the factory colours and then lengthening and adding new spades as required.
dunno if i helped at all
Ian
yellow/black could be to the headlight left side low beam.
yellow/black can go to the heater blower motor.
Finally ended up taking the knee bar off and front seat out and getting under the dash to get the numbers from the (6 pin) ignition switch, then with lots of reading and googling I finally put it all to gether and am pleased to say that it fires, runs and most inportantly turns off now from the key.
This is the diagram I finally made for myself to work from and it seems to work, so I will put it here incase someone in the future needs something similar
The old fix of twisting wires together…. a fire waiting to happen…. is that how you found the wiring?
mark1gls said
Good to hear you fixed it.
