Electrical gremlins interfering with ignition
(In Topic #215090)
I have this weird electrical problem with my golf. I was driving the car daily untill one day it started running really rough and eventually died. The symptoms i had at the time were a clicking noise from a relay (though not as frequently as shown in the video) and the tachometer needle jumping irregularly. I suspected the problem would lie in the ignition system because my sparkplugs were fouled. Since then, everything on the ignition system has been replaced: coil, sparkplugs, sparkplug wires, distributor, vacuum advance, points, capacitor, rotor,... After all of this, it refuses to run properly and the clicking relay problem became worse. I suspect there must be a ground issue or something wrong with the fusebox? Im not really an expert on diagnosing electrical gremlins so every piece of advice is greatly appreciated. Thanks in advance.
Video showing the problem:
https://www.youtube.com/watch?v=swr9ICVQ9iE
Take a photo of your fuse box set up and post it on here.
Tell us which relay you can hear clicking.
Then the electrical experts on here have something to get there teeth into, remember the devil is in the detail! 😉 👍🏼
I just checked which ones are clicking by pulling them out one by one. Turns out its all of them!
I tried pulling out the yellow plug but it just stopped the clicking, not the stuttering
