Citi Golf Temp Light
(In Topic #212730)
Sent from my SM-A300F using Tapatalk
Check that your coolant is at the max fill line.
If it is at the min, then as you drive you may suck it down enough to uncover the probes.
The Probes also get calcified and will not be at the proper resistance to keep the lamp from flashing.
You may need to clean the probe tips.
