Timing belt replacement and engine setup help
(In Topic #217115)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1494940448098.jpg)
![Asqs342 in the usergroup ‘Regular’ Asqs342 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Good morning all,
I know that there are a multitude of answers on this subject but trying to relate them to my issue is difficult.
In essence my 1.8 DX has been fully stripped and i am in the process of putting it back together. Engine is out on stand and gearbox off.
When stripped everything was removed and replaced with new so i want to make sure i have set everything up right before i get it back in the bay.
From bottom up:
I have piston 1 at TDC and have checked this through the spark plug hole.
The intermediate shaft is rotated so that dizzy is pointed at firing cylinder 1.
The bit i am struggling with is the cam. As i took the cam off, it can be replaced at any rotation in theory. Even though i have line lined up with top of head, how do i know by looking at valves if this is in the correct rotation. Looking at it now, Cylinder 1 are both closd. Is this correct.
TO be honest, first time i have went this far alone and for obvious reasons want to make sure this is right before i go any further.
If it is out and its started what will happen???? obviously wont run but can it cause internal damage?
Thanks in advance for help.
Carl
From bottom up:
Carl
Re: Timing belt replacement and engine setup help
A few pics of where I am. Timing belt still not on yetAsqs342 said
Good morning all,
From bottom up:
Carl
![](https://uploads.tapatalk-cdn.com/20180408/a79d2d5b495b743406faaea615e49346.jpg)
![](https://uploads.tapatalk-cdn.com/20180408/a3fabcc387224067118023581ea9f1d8.jpg)
![](https://uploads.tapatalk-cdn.com/20180408/817fbc683b52e9b9f181f9197e572083.jpg)
![](https://uploads.tapatalk-cdn.com/20180408/e0e90dbe24a2bf5defd64eccbb852a2c.jpg)
![](https://uploads.tapatalk-cdn.com/20180408/f90dd3e5d623f64adb3f4b0953335a96.jpg)
![](https://uploads.tapatalk-cdn.com/20180408/42c211fb8b7e0fca1c5a16c75cae79d3.jpg)
Sent from my VTR-L09 using Tapatalk
Re: Re: Timing belt replacement and engine setup help
When a cambelt pulley is as per last photo then cylinder 1 valves are as per this photoAsqs342 said
Good morning all,
From bottom up:
Carl![]()
![](https://uploads.tapatalk-cdn.com/20180408/e01bc5db94061abf1087ff54e51294e7.jpg)
My timing marks for the cam shaft are on the inside of the cog/pulley?
There is marks on both sides of the cog as it's the same cog/part for the cam shaft and intermediate shaft.
Like this.
View topic: Help confused- Timing marks - The Mk1 Golf Owners Club
Once the belt is on turn the engine over a couple of times to make sure it turns overs with out hitting anything inside.
When ready to start it for the 1st time after a rebuild remove the rotor arm and turn it over on the starter motor for a minute or so, this will help bring up the oil pressure and pump some oil around the engine before it starts.
Like this.
Crank at 0 TDC by the finger of the tranny to the (0) stamp on the flywheel.
Diszzy in the middle of the hash on the side frame.
Cam has a dimple on the back that is even to the plane of the heads valve cover,,,The number one lobes are pointing up.
nice write up with Pictures.
http://www.cabby-info.com/Files/AdjustingTheTiming.pdf
Re:
Thanks Mark. That link is taking me to homepage for some reason. I intend to get this finished and have a look when I get back later.mark1gls said
Like this.
Thanks again
Re:
Really useful link there which I will work through when I get home later. Thanks againBriano1234 said
