Suspension problems - can anyone advice/help
(In Topic #215162)
![IanRBrown in the usergroup ‘Paid Member’ IanRBrown in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![IanRBrown in the usergroup ‘Newbie’ IanRBrown in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
1983 MK1 GTI suspension issues
I bought a 1983 Golf GTI about 6 weeks ago. The guy had done a lot of work on it, including changing the suspension. When I bough it had a rattle coming from the back. He said he though it was exhaust so I assumed it would be an easy fix. The rattle is only there when driving in built up areas where roads are rougher - it is fine on motorways and smooth roads. I've had a friend of mine who is a mechanic look at the car and he says the suspension that is on it is a racing suspension which is very stiff and it also has a polybush kit fitted which he says is making it worse. He says that this is what is causing the rattling first because the car is so stiff that it's not able to absorb bumps in the road.
My first questions is does anyone else know about this issue and is his diagnosis correct. My second question is would retuning the suspension to a standard kit help? If yes, where is the best place to get a standard suspension kit?
Regards
Ian
If it's had coil overs fitted you will need the front struts, cups at the top a few washers.
Rears not so much a problem as the kit comes with most of the bits but you still need to top cup as not sure if coil over tops fit the springs?
Good kit to slightly lower the car and still a comfortable ride.
http://www.ebay.co.uk/itm/Eibach-Lowering-Springs-Bilstein-Gas-Shocks-Bumpstop-Kit-Golf-Mk1-/231605051979?hash=item35ecbca24b:g:gB8AAOSwCGVX4nxx
If you post up a picture of front and rear struts we should be able to tell what's fitted.
Standard rubber bushes are still avaible so easy to get hold of.
Are you sure there is nothing rattling in the boot? Jack in the spare wheel etc???
I also re-ran the resonator to silencer pipe to make more clearance in the thing.
Also validate that all the silencer hangers are good.
They only lower the car a little so I still don't have to worry going over those speed bumps in the middle of the road.
I'm in my 40s with 2 small children so a comfortable ride is more important than looks and the Golf is my daily drive. I'm going to change to the Eibach/Bilstein set up on my Golf next year as I found the Boge standard shocks don't seem to last long, 1 of mine is worn after 2 years/ 20,000 miles….
Not 100% sure you can get new standard springs for the GTi as they are stiffer and lower than the standard car.
Places to get bits from
http://www.classic-vw.co.uk/front-suspension-359-c.asp
Website being updated.
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
New top mounts is also a good idea, Febi are the better make as I found the Meyle ones only lasted 12 months on both of my cars when I thought I'd give them ago…
https://www.vwheritage.com/171411105g-front-spring-standard-mk1-golf-scirocco-jetta-79-83
