Starting/running problem
(In Topic #223798)
![lawce70 in the usergroup ‘Local’ lawce70 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![Steve1973 in the usergroup ‘Local’ Steve1973 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The cause of your trouble is more than likely going to be the ballast resistor wire which will have broken. I would fit a 12v coil, you should have a 9v with ballast resistor ignition, and run a new standard wire.
The other solution if you do have the 9v coil is to buy a resistor on ebay, they're about £5, and run a new wire to the coil with that in the circuit.
![steve1948 in the usergroup ‘Regular’ steve1948 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
