Parts help
(In Topic #221569)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/bird.png)
![Bogwarrior in the usergroup ‘Newbie’ Bogwarrior in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Just need to fix a few bits before an upcoming vintage run and would like to get sorted before it. I'm hoping this post is ok and maybe someone can help guide me before I order or recommend best place to purchase…
Car is 1984 MK 1 Golf GTI 1.8 DX(?) manual
I need to following parts and if someone more familiar would be able to confirm if these are correct it'd be super!
Front wheel bearing
https://eu.vwheritage.com/171498625d-wheel-bearing-kit-front-vw-spare
Bottom ball joints (in case they are damaged taking out drives)
https://eu.vwheritage.com/171407365fg-ball-joint-vw-spare
Gearbox drive (1/2) shaft seals - inner ones on gearbox x 2 - this is the one I'm really unsure on…
https://eu.vwheritage.com/020301189-gearbox-drive-flange-seal-vw-spare
Rocker cover gasket
https://eu.vwheritage.com/026198025a-rocker-cover-gasket-kit-16-18-cork-vw-spare
Thanks in advance!
![Avatar](https://i295.photobucket.com/albums/mm141/deutsch36/skull_150-1.gif)
![totenkopf in the usergroup ‘Local’ totenkopf in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
https://www.volkswagen-classic-parts.de/catalogsearch/result/?q=171407365&order=relevance&dir=desc
https://www.volkswagen-classic-parts.de/catalogsearch/result/?q=020301189&order=relevance&dir=desc
https://www.volkswagen-classic-parts.de/catalogsearch/result/?q=026198025A&order=relevance&dir=desc
