Kr won't start help please
(In Topic #219125)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/berries.png)
![mayo6650 in the usergroup ‘Newbie’ mayo6650 in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Another kr problem
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![Steve1973 in the usergroup ‘Local’ Steve1973 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
It normally only prevents starting when warm, because the 5th injector should fire when cold - does yours?
It can be easily tested by squirting Easy Start, or petrol, or brake cleaner etc into the air intake just before trying to start - it will be enough for a few seconds, to start the car, then the fuel pressure will probably build up.
Check the obvious - that the pump isn't restricted (small filter blocked up on its inlet?) poor wiring, poor relay, and the 5th injector etc
