Getting rid of air box
(In Topic #217381)
Replacement air filter
You can also suffer from the carb freezing in cold weather if you get rid of the air box as it also has a hot air feed when the car is cold.
Best upgrade is a panel K&N air filter which fits inside the original air box, you may get 1 bhp more but I don't think you will notice the difference but you will never need to buy a air filter again.
https://www.ebay.co.uk/itm/VW-Golf-Mk1-Mk2-Jetta-Caddy-1-5-1-6-1-8-K-N-Air-Filter/141600071190?hash=item20f8059e16:g:TPYAAOSwYgFan73w
Are you missing the cover? It looks like this, 1st one I found, shop around as this one is expensive for a bit of plastic…..
https://www.ebay.co.uk/itm/VW-GOLF-JETTA-CADDY-MK1-CENTRE-CONSOLE-GAUGE-BLANK-COVER-TRIM-171863267A/152760027010?hash=item2391350782:g:N0cAAOSwWLBZ8erF
Not sure on inner lights but I guess you can get some new fixings?
Last edit: by mark1gls
I think Mk2 golfs had the same inner spot lights as the cabriolet?
This may work but have a look at what your are like…
https://www.ebay.co.uk/itm/VW-GOLF-MK2-GTI-NEW-FRONT-HELLA-GRILLE-GRILL-SPOT-LIGHT-ADJUSTER-SET-of-3-G60/222952942093?hash=item33e907ea0d:g:4EUAAOSw9itZpS4n
There is a few different sets on eBay.
Might also be worth phoning your local VW dealer to see if they can get some or maybe give you a part number, I have found that sometimes theVW dealer is cheaper than eBay….
